Bushings - OEM vs poly - Page 2 - Defender Source
Old May 16th, 2015, 02:38 PM
Rovers North, Atlantic British, Craddocks, Paddocks, Ebay, etc...
Old May 16th, 2015, 02:41 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Originally Posted by alecbeard View Post
Where do you find these?
you could always try the goggle method and search flo-flex bushings, it pops up straight away
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 16th, 2015, 02:45 PM
alecbeard
Alec Beard
1972 Series III
My problem is finding things in the US. I have not found a US source for Super Poly or Super Pro or whatever the name is. Flo Flex is also a UK thing, right? Poly pro sells some stuff at Atlantic and Rovers North, but not a complete line.
------ Follow up post added May 16th, 2015 12:49 PM ------
My apologies. I knew of Craddocks and Paddocks but looking on their website I got the impression they didn't deliver to the US. Turns out they do. Sorry for the stupid question.
Old May 16th, 2015, 03:30 PM
Not stupid at all. Well, from my perspective at least.
Be warned that paddocks will charge you a minimum shipping fee of $50 USD. You do not want to order a pair of bushings from them. John craddocks treated me very well in the past as well.
Old June 13th, 2017, 04:18 PM
DCG's Avatar
DCG
David
1984 110 CSW 3.5 V8 LHD
Life-span of stored genuine bushings
I had new bushings pressed into my A-arms and trailing links ~16 years ago, but were never reinstalled. The A-arms and trailing links were stored in an air conditioned house. What is the life span of genuine bushings? At 16 years with no actual use, should I just replace them?
Old June 13th, 2017, 05:05 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
My problem is finding things in the US. I have not found a US source for Super Pro
There are hundreds of US Super Pro dealers. That being said you will be hard pressed to find a US dealer that stocks them. I suggest Ebay UK.
Dealer, Distributor and Fitter Locator - SuperPro
Old June 13th, 2017, 11:56 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Could one of the reasons for poly bush failure be lack of grease? In operation they behave differently from rubber. Rubber bushes flex within their material thickness and are restrained on the ID and OD. Not so with poly. Some suppliers include grease, others nothing.
I have not tried poly on my 90, but on the trailing arms of Triumph TR's some instal zerks.
Old June 14th, 2017, 12:58 AM
Naplm00
Matthew
I have the yellow britpart bushings, they are like the day I installed them. Greased well and holding up great. So much easier to install than oem!
Old June 14th, 2017, 07:10 AM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
My Landy still have the original 17 years old bushing and look fine and flexible every time I inspect them except for some shrinkage on the trailing arm chassis rubber.... So I guess you're fine.
Sent from my SM-G920F using Tapatalk
I'm for the Russian pencil
bushings, oem
Poly bushings Jake1996d1 Wanted 17 December 14th, 2012 02:54 PM
poly bushings roverman2010 Wanted 0 November 12th, 2012 01:58 PM
Poly Bushings? Use or Not? Hammertime Defender Technical Discussions 19 August 6th, 2011 04:05 PM
Body bushings - poly or factor rubber?? jaherring Defender Technical Discussions 15 February 10th, 2005 06:42 PM
