burping the coolant - Defender Source
Old May 29th, 2006, 12:36 AM
mattdh's Avatar
mattdh
Matt Hurst
burping the coolant
i read to do this -remove the plug to the pipe leading to the heater hoses and start the engine. how is this supposed to work?i have tried it twice and coolant just comes pooring out after i start it up
Old May 29th, 2006, 12:44 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Since this is a vertical pipe, any air bubbles going through the system go up the pipe when coming back from the heater (or going to it, can't remember)--it is also the highest point in the system. You want coolant coming out of it--it does not mean all the air is out, but it is the best place to drain the air.
Old May 29th, 2006, 01:56 PM
mattdh's Avatar
mattdh
Matt Hurst
so is this the only way? i would guess i will loose a few gallons of coolant
Old May 29th, 2006, 02:06 PM
Chris V
Guest
Posts: n/a
Drive it up an incline first (nose of the rig up in the air) then try and bleed the air out.
coolant
Engine Coolant what kinda rover4x4 Defender Technical Discussions 12 May 17th, 2009 11:02 PM
coolant - which to use scoloco Defender Technical Discussions 37 May 2nd, 2009 04:24 AM
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
