burning up coils - Defender Source
Old July 23rd, 2005, 03:50 PM
tmore
Tom More
1995 D90
burning up coils
I am on a two month stretch of ignition problems.. Iwas fighting a problem where my vehicle would randomly stall while driving.. It seems that new ignition module #2 did the trick.. My new problem is that my coil is generating a lot of heat and burning out.. Two coils in the last 5 weeks.. I had thought that the first one was defective and replaced with a new bosch.. last night I was parked with the engine not running but the ignition switch and sereo on for a couple of hours and smelled something burning.. Opened the hood and had a lava flow coming out of my smoldering coil.. put a spare coil in and it started up and ran fine but it still seems that the coil is getting way too hot.. in the last two months I have replaced the inition module, coil, plug wires, plugs, cap , rotor..
Any suggestions??
Old July 23rd, 2005, 04:27 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I'd get a voltage meter in there and check that you aren't pushing too much into the ignition system..... your voltage regulator may have gone bad.
-Hans
My oil line fix
My 100k stopped odometer fix
Old July 23rd, 2005, 07:43 PM
tmore
Tom More
1995 D90
Checked the voltage and it is at about 12.4v.. seems to be about normal?
coil
Safari Gard Progressive Coils SafariGard The Vendors Loft 2 March 8th, 2009 03:06 PM
Weird sparking around coils flynn23 Defender Technical Discussions 8 August 11th, 2008 11:13 AM
Question about burning smell michael15 Defender Technical Discussions 13 March 7th, 2006 01:30 PM
Weird burning smell in 5th gear? oldscratchggf Defender Technical Discussions 7 February 14th, 2006 09:09 AM
burning coolant mattdh Defender Technical Discussions 2 July 19th, 2005 05:29 PM
