burning coolant - Defender Source
Old July 18th, 2005, 11:43 PM
mattdh's Avatar
mattdh
Matt Hurst
burning coolant
i am getting a lot of white smoke -is there away to tell for sure if it is coolant.if it is how much damage could this do or what are the consequences?it is a new 4.6 block new composite head gaskets.my valey gasket is new but my guess would be this gasket if i had to guess.
Old July 19th, 2005, 08:47 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Chris Davis just went through that with his 4.6 upgrade. There is a recent thread he started where I think he described how to check for coolant where it doesn't belong.
Out of curiosity, did you re-chip? I read somewhere that the 3.9 chip in a 4.6 causes the engine to run too lean and can cause problems like you are experiencing.
Old July 19th, 2005, 05:29 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
White always = coolant. White is steam. Blue is oil. Black is gas.
Doug W.
coolant
Engine Coolant what kinda rover4x4 Defender Technical Discussions 12 May 17th, 2009 11:02 PM
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Weird burning smell in 5th gear? oldscratchggf Defender Technical Discussions 7 February 14th, 2006 09:09 AM
burning up coils tmore Defender Technical Discussions 2 July 23rd, 2005 07:43 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
