burned hand brake cable & starter motor ? - Defender Source
Old February 23rd, 2014, 08:37 PM
Billyboy
Bill Struthers
2010 defender 90
Angry burned hand brake cable & starter motor ?
Just wondering if anyone can throw some light on this issue I have with my landrover Defender 90.
I purchased a 2010 Defender 90 recently so its still under a 3 monthy aussie warranty but I have a rather interesting issue the hand brakes keeps burning out including the original starter motor ,must be drawing current from somewhere and using the HB Cable as an earthing point ,any auto mechs throw any light on this as my local mechs a bit baffled ?
wondering if anyone has had the same problem ,there is a lot additional attachments fitted to the landy ,ie winch etc
so if anyone hads any ideas please let me know ??????
thanks
Old February 24th, 2014, 03:36 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Bill,
It sounds as if the engine earth strap is loose missing or corroded, when you start the vehicle the earth connection is via the handbrake cable.
This is a common issue, I have made jump links for my 90 that link either side of the engine mounts and gearbox mounts I've also upgraded the size of the earth cable & made sure there are a couple of earth connections from the battery.
If you have a woven wire earth strap bin it..
regards
Gren
Old February 24th, 2014, 09:58 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Originally Posted by Gren_T View Post
Hi Bill,
regards
Gren
Some of what he said, but I have found that allot of people who remove engines forget where (sometimes) the earth strap was fitted. I have come across earth straps fitted to the bolts where the bulkhead bracket is bolted to the chassis. There is no internal tubes inside of the chassis at this point, so All you are doing is squeezing the chassis together and will never get a proper earth.
The strap should be fitted to the left hand engine mount bracket of the chassis and should be a hole facing aft for it (sometimes)
The welding of the hand brake cable was/is an on going fault to D2's as the strap comes loose.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 25th, 2014, 10:57 AM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
It is always a good idea to run a ground strap directly from a starter motor mounting bolt to the chassis. And to remove any paint between the bolt and chassis or starter motor flange where the cable will touch. paint acts as in insulator.
So you drive a Series IV Land Rover which is why you are posting in the Series LR section. At least your problem is something we all have in common.
TeriAnn
Old February 27th, 2014, 06:28 PM
Billyboy
Bill Struthers
2010 defender 90
it looks like the prob was in the battery bay its self, the aux Battery was moving backwards ? and touching the metal support strap and arching out ???? go fig? but I only got it back yesterday so watch this space for further developments but in the mean time,the techs have placed some shrink sleaving on the strap to prevent it happening again etc
brake, motor, start, starter
2.5NA Starter Motor Issues Michael110 Defender Technical Discussions 3 February 24th, 2014 12:54 PM
Rebuild kit for starter motor ini88 Defender Technical Discussions 1 May 23rd, 2008 04:50 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
» Defender Registry
Rapier
HAWKER748
Lola
Nooner
Add your Defender
