Bumpstop pic request - Defender Source
Old June 20th, 2006, 02:32 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Could some one post a pic of a stock 90 rear bumpstop so I can tell if the one still remaining on my Series coiler is the same? Thanks in advance.
Old June 20th, 2006, 04:47 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
I don't have a pic, but a Defender bump stop has the mounts at the ends and a Series one has the mounts on the sides (like ears).
Most coil frame builders use the Series bump stop and they bend the ears (mounting tabs) up and use one cross bolt through the frame rail to hold it in place. A Defender one would take 2 bolts, one at each end.
Hope that helps.
Email:
Old June 20th, 2006, 05:01 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
RightO you are, since you guys built it of course (back in 95-96). Thanks.
Old June 20th, 2006, 05:08 PM
ECR's Avatar
ECR
Which one?
If we built it we have all the part #s you would need to replace equipment that is on it (or was when it left here), just call or email with your needs.
Email:
Old June 20th, 2006, 06:43 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
Kevin's ride
Old June 20th, 2006, 08:22 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Yep, it is still on your website actually, done for Sam Brooke originally. Lots been changed since it left you guys, new motor, radiator, roof rack, winch mount etc. I rebuilt the brake system, converted the rear to 24 spline and locked it, springs, shocks, shock mounts, Rovertracks links, relocated steering stabilizer, HD tie rod and drag link, CB, canvas top, soon to get a Safety Devices roll bar, OD removed, winch overhauled, Tom Woods rear shaft, wheels and tires and lots more I'm forgeting. Nice to see the old work not die I guess.
Old June 21st, 2006, 05:53 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Hey Kev.......my trucks dirtier than yours......or pretty much anything.
where did you get the Safety Devices cage?
Matt Browne
Old June 21st, 2006, 09:10 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Local buddy has one in his garage that he never installed. He was going to put it in the IIA he restored so he'd feel better taking the family along, but then went and bought a D1 for that. That pic was from the warm spell in April, you know it's been plenty dirty since then, couple more dents too.
Pic request crown14 Defender Technical Discussions 10 September 13th, 2009 10:21 PM
Badger II questions/ pic request oldscratchggf Defender Technical Discussions 17 July 27th, 2008 04:05 PM
post a pic for me? mattdh Defender Technical Discussions 1 October 29th, 2004 12:22 PM
Another good Pic from Iraq OCD90 Misc. Chit-Chat 4 April 14th, 2004 12:45 PM
