Bumper captive nut tricks - Defender Source
Old October 4th, 2014, 10:53 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Does anybody have any? It's been eight years since I last fitted this bumper and I had totally forgotten about what total hell it is to align the captive nut plate. I've thought about removing the plate from the flimsy carrier that seems to be fouling the bolts but I'm not sure if this is a good idea.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old October 4th, 2014, 11:00 PM
Some bolts have pointed ends. Honestly I have never had an issue doing it.
Old October 5th, 2014, 03:38 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Clean everything up, bolts & nut plate, grease or waxoyl it and don't push too hard when spinning the bolts in to start with. Never really had a problem either. Steering boxes...now that's another issue entirely...
Mike Hammond
Old October 5th, 2014, 09:39 AM
Did this recently without too much trouble with bolts that did not have the pointy ends. It helps to have someone lend a hand - one to turn the wrench while supporting the bumper and the other to align/guide the backing plate with a screwdriver at eye level.
Originally Posted by pendy
I'm here for the D's
Old October 5th, 2014, 10:09 AM
I used normal nuts on mine. I hole sawed access from below to get a socket in the bottom.
When the captive plate corrodes, it is real pain in the ass to get things out of there.
Old October 5th, 2014, 10:25 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Stick them in place with masking tape or squishy double sided tape (mounting tape).
I fought with the blasted things until I noticed bits of masking tape in there...I was con Ernest that masking tape would hold moisture so I used some 3m synthetic mounting tape.
Old October 5th, 2014, 10:41 AM
I always get one bolt started and use that same bolt to rotate the plate around to line the second bolt up. Then I hit it will the 3/8" impact and hope it doesn't cross thread. If it does cross thread, just remember, a crossed thread is a tight thread
Old October 5th, 2014, 11:46 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Did they not come with the thin metal alignment holder thingy? I have never had a problem with brand new ones and have only ever installed bumpers by myself. I just would get one aligned with maybe a little help from the other hand to ensure the plate holds exactly where I want when putting in the second bolt. dfx
bumper
Riveted captive Nut for seat frame bjf Wanted 7 July 10th, 2012 06:59 PM
ALQ710020 Bumper Captive Nut Block jefhuf Wanted 4 October 23rd, 2011 11:03 AM
ST b-pillar diagonal support captive nut plates dave_lucas Wanted 12 September 9th, 2011 02:57 PM
captive nut for wing intake cover Overlander Defender Technical Discussions 3 July 20th, 2008 11:51 PM
Winch Bolt/Nut locks - like wheel(lug nut) locks Jase Defender Technical Discussions 4 February 20th, 2005 08:31 PM
