Bulkhead Wire Ties - Defender Source
Old December 12th, 2012, 01:08 PM
61rover's Avatar
61rover
John Crouse
Bulkhead Wire Ties
Sorry for the blurry IPhone pic, but does anyone know the part number for these wire ties on the bulkhead? Or who might have them? They are like zip ties but with a piece that anchors through the bulkhead.
Old December 12th, 2012, 01:12 PM
The Dro
Dro
1988 Ninety
They are called Clamp Ties.
Panduit... Tyco... to name a few has them.
You can buy them at Home Depot too.
Here is the Panduit link
Home Depot link
Old December 12th, 2012, 01:15 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
They are tie-cable, 6.5mm hole x 155mm panel fixing. part # AAU3686
Some others available too:
7mm hole x 165mm YQR10016L
8mm x 215mm YYD10003
Old December 12th, 2012, 01:16 PM
61rover's Avatar
61rover
John Crouse
These have a post that goes into the bulkhead and anchors them.
Old December 12th, 2012, 01:19 PM
The Dro
Dro
1988 Ninety
see my previous post.
Old December 12th, 2012, 01:23 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
That's what these ones are: # AAU3686
they fit a little like the plastic rivets that hold the rubber wheelarch eyebrows on... plastic "pin" you tap through the middle to expand the claws inside the hole.
Old December 12th, 2012, 01:42 PM
I know I got some from RN and they were not fall over expensive.
Old December 12th, 2012, 02:36 PM
61rover's Avatar
61rover
John Crouse
Thanks everyone!
Speaker wire rubber grommets for TD5 style bulkhead and doors dave_lucas Defender Technical Discussions 1 April 22nd, 2012 11:58 AM
LHD TD5 bulkhead wire loom rayfi For Sale - Parts 2 November 7th, 2009 01:59 PM
Best way to pull wire through bulkhead WI-ROTTIE Defender Technical Discussions 4 March 25th, 2008 04:23 PM
