Bulkhead/Windscreen seal, which one from McMaster? - Defender Source
Old October 21st, 2009, 04:01 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Keith at BP told me the EPDM seals at McMaster are much better than genuine. I'm looking to do the entire roof (fiberglass) windscreen to roof and bulkhead to windscreen. keith says its all the same 1 inch width seal. Do you guys think the 1/4 93725K78 is thick enough for the bulkhead windscreen? http://www.mcmaster.com/#catalog/115/3488/=45rewz Thanks for your help.
neil
Robert Deniro
Old October 21st, 2009, 05:02 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I have a new windscreen to bulkhead seal at home if you would like me to measure it.
Old October 21st, 2009, 05:16 PM
Neil McCauley
Neil McCauley
That would be awesome!
Neil
Robert Deniro
Old October 21st, 2009, 06:57 PM
I just ordered a roll of 8694K73, and I think it would be ideal for you application.
Old October 21st, 2009, 07:14 PM
Neil McCauley
Neil McCauley
Thanks Jim I'll check this out.
Neil
Robert Deniro
Old October 21st, 2009, 07:56 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
1.200 Wide
.300 Thick
thickness was measured with the paper still on the sticky side
Old October 21st, 2009, 08:15 PM
Neil McCauley
Neil McCauley
Thanks I'm going to Mcmaster this Sat and try to see whats the best replacement.
Neil
Robert Deniro
master
Pinion Seal Leak, Salisbury Diff Doug Defender Technical Discussions 18 August 8th, 2016 03:07 PM
Seal at axle tube/swivel ball snuffer Defender Technical Discussions 8 February 7th, 2011 05:06 PM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
Seal on the Driveshaft dbwitt Defender Technical Discussions 8 May 14th, 2004 12:18 PM
