Bulkhead / Vent Repair - Defender Source
Old November 7th, 2011, 07:37 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
I posted a similar inquiry a long time ago, but received no responses that resolved my issue. I am hoping that I'll have some luck this time. My bulkhead is generally solid except the area just below the winscreen (above the front vents). The corners are great (they may have been replaced at some time) and the door pillars are top notch. The steel above the vents (particularly where the vent hinges attach to the bulkhead) are starting to show some rust through. Are there any replacement components, similar to the corner pieces that are available at Rovers North? Any UK sources? If not, I guess I will have to see if I can find the rare commodity of a body shop that actually has an experienced metal worker / fabricator. Thanks in advance for any advice.
Old November 7th, 2011, 09:28 PM
grnrvrs's Avatar
grnrvrs
Paul
88
YRM make some interesting bits: http://www.yrm-metal-solutions.co.uk
There used to be some repair panels that covered the entire top portion, corner to corner including the vents. I think it was Craddocks.
1970 SIIA 88, Sold
Old November 7th, 2011, 11:00 PM
61rover's Avatar
61rover
John Crouse
I have a bulkhead repair panel that I'm not going to use. It replaces the entire top from below the hood to the windshield and side to side. I ordered from the UK, but found a replacement bulkhead.
Trying to find a photo. PM me if you're interested.
Bulkhead Corner Repair Piece The Dro For Sale - Parts 6 December 6th, 2011 07:36 AM
Upper Bulkhead Repair Question isleofbones Defender Technical Discussions 4 April 13th, 2011 03:18 AM
series bulkhead repair orionpco Series Technical Discussions 9 July 21st, 2010 02:27 PM
Bulkhead LH footwell repair panel? turbodave Defender Technical Discussions 1 August 22nd, 2008 03:03 PM
Bulkhead repair 61rover Defender Technical Discussions 1 May 19th, 2008 03:33 PM
