Bulkhead vent pin removal - Defender Source
Old March 1st, 2011, 02:12 PM
seriousactualist
Paul Martin
1995 D90 ST
I've seen threads on replacing the vent seals. I'm curious how folk are removing the two hinge pins on each vent flap without damaging the pin, etc.
Thanks for the indulgence!
-- Paul
Old March 1st, 2011, 02:35 PM
bjf's Avatar
bjf
barry f
94 ST #395
Pins are cheap. I think I bought them from George for 3 bucks a piece. Just get touch up paint to repaint the heads
Old March 1st, 2011, 02:51 PM
seriousactualist
Paul Martin
1995 D90 ST
Thanks, Barry! Any tips on removal technique?
Old March 1st, 2011, 02:53 PM
Rugbier's Avatar
Rugbier
Gustavo
needle nose, press the open side ( normally facing inward from the sides ) and push them
simple and easy
NO SIGNATURE
Old March 1st, 2011, 02:57 PM
Mask up the area well ... the glue for the vent seals is a bitch to remove .... ask me how i know! ;-)
Old March 1st, 2011, 03:10 PM
bjf's Avatar
bjf
barry f
94 ST #395
I second that on the vent seal glue. I am assuming you are going the rubber route
Old March 1st, 2011, 03:39 PM
seriousactualist
Paul Martin
1995 D90 ST
I have a set of the SIII rubber seals (MUC4299) on the way and a set of the adhesive-backed JAE000030 seals in the garage (which I'm not planning on using).
I'll have a look at the other threads for a good and suitable adhesive for the application.
Thanks!
Old March 1st, 2011, 07:01 PM
3m rubber glue from autozone ...
Old March 1st, 2011, 10:16 PM
jhhorse
joe heins
1995 defender 90
The pins come out easily using the technique already mentioned. If you want to remove the vents to put genuine seals on, you have to pull the bracket off by removing the small screws holding it on, a much more difficult (in my opinion) task than the pins. Just takes a tiny wrench and a lot of patience
Old March 6th, 2011, 03:56 PM
seriousactualist
Paul Martin
1995 D90 ST
I've been out of town most of the week, but got the vents off before I left. Happily I could get my little 8mm wrench in there.... Much easier after removing the section of the cage.
I've (mostly) cleaned the old crap off the back of the vents. Now waiting for my SIII seals to arrive, which seem to have mysteriously been sucked into a vortex somewhere between Valencia, CA and Seattle.
Thanks!
-- Paul
Old June 30th, 2011, 04:48 PM
OahuDefender
Jason
1994 D-90
Where do I find the non-adhesive seals and vent pins online?
Old June 30th, 2011, 06:59 PM
Has anyone tried retro fitting the new style bolts to replace the old spread pins ?
Frozen bulkhead bolts removal suggestions? Tyler Wirken Defender Technical Discussions 12 July 23rd, 2008 04:29 PM
Bulkhead removal bar Jase Misc. Chit-Chat 2 June 9th, 2006 11:49 PM
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
