Bulkhead Thread - Page 9 - Defender Source
Old February 2nd, 2015, 08:03 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Got the RHD vinyl cover put back on. I have a leather cover that came in from that seller on eBay that was mentioned. But it came in a little messed up. I am in talks with the seller to get it sorted. If I had a good RHD lower dash to start with it wouldn't have been a bad exercise at all. Especially with LHD lower dashes listing for over a grand.
Old February 2nd, 2015, 08:55 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Don,
Before you install the lower dash, run a bead of seam sealer over every seam. I neglected to do so when I initially built my 110. This past summer, I pulled the entire dash apart to put some second skin LLP behind the entire dash. At the same time I sealed all of the seams in the lower dash. It made a HUGE difference in the heater air flow.
1970 SIIA 88, Sold
Old February 2nd, 2015, 09:26 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by grnrvrs View Post
Don, Before you install the lower dash, run a bead of seam sealer over every seam. I neglected to do so when I initially built my 110. This past summer, I pulled the entire dash apart to put some second skin LLP behind the entire dash. At the same time I sealed all of the seams in the lower dash. It made a HUGE difference in the heater air flow.
Thanks for the tip. Was hoping people like you would chime in with things that work and don't work. I was thinking running something on the inside edges of the lower dash and will definitely do it now. And any old seam sealer from NAPA / Pep Boys.
I forgot to mention it but I put some foam padding I got from the hardware store on the flaps so they would seal better if closed.
Btw - what do you mean by second skin LLP? Would the dynamat be similar to what you did?
Old February 2nd, 2015, 09:27 PM
Originally Posted by don View Post
Lol - I want to see how it looks myself! I think the galvy with the blue will be a nice contrast. I am stripping the blue off the vent covers and will polish them and run polished windscreen brackets too. My plan is for the galvy to fade and have that natural look and feel like a weathered cedar roof and darkened cooper gutters (which I have on my house).
I'm looking forward to seeing it too! Keep up the good work.
Originally Posted by pendy
I'm here for the D's
Old February 2nd, 2015, 09:51 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Second Skin Luxury Liner Pro, good stuff. Each manufacturer of sound control insulation has their own set of products. Some are designed to change the resonance of panels ( what you are using), some are designed to block certain frequencies and some are designed to absorb certain frequencies. I am unaware of a silver bullet for sound insulation. Different products/tools for different jobs.
1970 SIIA 88, Sold
Old February 2nd, 2015, 10:03 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks for the details
Old September 26th, 2017, 02:17 PM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
Just thought this thread was long overdue for a revival. Picked a couple more up from galvanising today.
ID:	303505   Click image for larger version
Patches are for Pirates and pants, not a bulkhead and chassis!
Old September 26th, 2017, 02:34 PM
amazing
