Bulkhead Thread - Page 4 - Defender Source
Old June 25th, 2014, 11:17 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by Ren Ching View Post
It was V&S. Everything we brought is well sandblasted, or new with no paint.
Let me know when you get yours back. I know it was just last week but I am itching to get mine!
Old June 26th, 2014, 11:06 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Got the original piece for the dash started on the patch/reinforced section. This is the top view.
This is the view from from behind looking up. So far it feels really solid and I only have a 1/3 of the piece welded on. Things are lined up better than how I got it and even tho my welds are looking sloppy, it is way better than the mig turds that were on there.
I have to figure out a way to fix the 3 gussets. But anything I do will be better than how they were just cracked apart and hammered flat.
I am going to flap disk the front side so there are no bumps but leave the beads on the back. The one small section I ground looks pretty seamless.
Old June 28th, 2014, 08:33 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Don, I've decided that when I get the truck painted, this piece of rover chrome will have to stay chrometastic. Looking good.
Old June 28th, 2014, 10:25 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks - I took the flap disk to that one section and it looks good. I think once it is all done and galvy'd and installed you won't even know there was a repair. Show your Rover chrome!
Old July 2nd, 2014, 09:03 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Got the NAS110 bulkhead back from V&S today. Bill was for $240. I thought it might be lower but not out of line for one piece. I need to bend some pieces back and clean up some areas. Not too bad save for a section along the windscreen seam. Not sure what happened as it looks like it just folded in on itself.
I ordered M12x180 bolts from McMaster Carr today. The only had grade 8.8 and SS so I got both. Not sure what you guys think of using stainless bolts in that area but the tensile strength according to McMaster's specs was 116,000 psi minimal for the grade 8.8 and 100,000 psi minimal for the stainless.
ID:	97991   Click image for larger version
Old July 2nd, 2014, 10:00 PM
Originally Posted by don View Post
Got the NAS110 bulkhead back from V&S today. Bill was for $240. I thought it might be lower but not out of line for one piece. I need to bend some pieces back and clean up some areas. Not too bad save for a section along the windscreen seam. Not sure what happened as it looks like it just folded in on itself. I ordered M12x180 bolts from McMaster Carr today. The only had grade 8.8 and SS so I got both. Not sure what you guys think of using stainless bolts in that area but the tensile strength according to McMaster's specs was 116,000 psi minimal for the grade 8.8 and 100,000 psi minimal for the stainless.
Just slather a ton of anti-sieze on the shafts of the bolts. Those guys always sieze.
Old July 2nd, 2014, 10:04 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Definitely! was going to put a ton of anti-seize on them on install. Those are just temp bolts - not long enough. Was wondering if the stainless ones would be strong enough - kind of leaning towards the 8.8 steels with a lot of grease.
Old July 2nd, 2014, 10:22 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Kind of leaning towards the 8.8 steels with a lot of grease.
Had the same dilemma. Went with the 8.8 and slathered them in anti-sieze. So far, so good.
1970 SIIA 88, Sold
Old July 2nd, 2014, 10:49 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
The main 2 bolts that mount the bulkhead to the outrigger? Shear strength is what matters in those.
-Jeff
And elasticity... - you want flex/deformation instead of brittleness as the bulkhead has both vertical and horizontal force applied to the hardware. Better to bugger the hardware with movement than have the bulkhead/chassis weaken from flex - or the bolts shear from a stress fracture. The sill rails take up some of the horizontal forces, the roof/windshield/floors absorb some of the vertical forces. In this instance I usually default to the OEM LR part as they are specified for the implied forces, though the 8.8 is a fine substitute - just clear coat or paint and apply anti-seize...
Old July 2nd, 2014, 11:04 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Jeff, grnrvrs, and MyBlueTT - will do the 8.8's for sure.
Old July 4th, 2014, 09:31 AM
flananuts
Matthew
Don, must be nice to get back to progress on your 110 build. Looking forward to checking it out
Old July 4th, 2014, 12:00 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Felt good to put it on! Gives the chassis some more dimension and me some motivation to get things moving along.
I am around today if you want to swing thru. I am about half way on that Td5 bulkhead and you can see in person what the galvy looks like.
BTW, getting the 2nd bolt on the bulkhead was a bit of a challenge. I read in LRM to bevel the end of an old bolt so it will self line up. It made sense when I read it but when executed the bulkhead would "snap" back as soon as the final bolt was hammered to the bulkhead/frame point.
I found a piece of 4x4 and cut it down to fit between the frame and bulkhead. Used some metal items I had around to keep the bulkhead in the correct position vertically and a clamp to keep the bulkhead from getting pulled back. Then grabbed a pry bar and got the bulkhead out enough for the M12 to go thru easy enough. (after using a bunch of grey anti-seize on it)
Old July 9th, 2014, 03:42 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Hope you don't mind me piggybacking on this thread but I was also having trouble finding the bulkhead info I was looking for by searching.
So my bulkhead is starting to show the first signs of a bit of rust so I want to remove it strip it, repair it and galvanize it.
I would also like to minimize the time the vehicle off the road so I'm hoping I can Pull the wings, floor panels, doors, dash etc and lift it out. I'm assuming this is doable?
If anyone knows of any threads with photos etc of this removal being done it would be great if you could direct me to it I know they must be out there.
Any tips or suggestions would also be appreciated.
Will
Old July 9th, 2014, 03:43 PM
defender1844
Amit Likhyani
I couldn't find it either. Thanks for asking.
Old July 9th, 2014, 03:49 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Yes its easy enough to do it this way.
Pull the bonnet, grille, wings, doors, floors, tunnel cover, unbolt the roof & raise it slightly, remove windshield, disconnect steering, disconnect cables, disconnect wiring, using straps with hooks in lower bulkhead feet and links bolted to upper door holes support bulkhead with crane or hoist from above, unbolt main bolts and secondary supports. Lift high and roll the truck away from the bulkhead, mount bulkhead to a jig or support and disassemble remaining dash/steering, pedal boxes, etc…
Old July 9th, 2014, 07:29 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Hope you don't mind me piggybacking on this thread but I was also having trouble finding the bulkhead info I was looking for by searching. Will
Will - I started this thread as a depository for bulkhead info. I couldn't find all that much myself. I bet a lot of people would be doing just what you are - remove/repair/replace an existing bulkhead.
Please post pics if you can - I printed out a bunch and keep them in my garage for references. But will need to find more when I start putting items back on mine.
Old July 9th, 2014, 08:13 PM
cbfritz_03
Carmen
none
Will
I documented a little something on the bulkhead removal on my build thread. There are a few pictures on posts #46 and #49. I've never removed one before either.
The advice I give is to take pictures or notes, tape or bag the pieces or bolts for an easier time when you go to reassemble. The bolts holding the wings to the bulkhead (on the inside) are a little hard to get to.
You will need an extension spanner.
Also, there are three bolts holding the bulkhead to the frame/rails; two smaller and one large. You might need a flash light to see.
If any of the bolts are too rusty; spray them and wait a few hours or over night and they will come out.
In my google searching beforehand I found a few things:
or Google "Landrover Defender bulkhead removal" and/or "PhilSheredan" ..he has a few short videos that were helpful to me. Good luck!
Old July 9th, 2014, 08:26 PM
cbfritz_03
Carmen
none
When you get going on yours and if you need an extra hand - let me know. I'd be glad to help
Old July 9th, 2014, 11:36 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I'm going give this a go in two weeks and try to do it all as fast a possible, I have a load of other bits to go to galvanizing and the bulkhead is the last piece. Hopefully it doesn't require too much welding...but I know once it comes off there will be surprises.
I will document the process and post here as I go along.
I'm currently trying to create a master list of all the seals, grommets, bolts, nuts etc that will need to be replaced so I have it all ready for re-assembly.
Just watched all the PhilSheredan vids, some good tips in there. Had a look at your thread too nice project! The more I see the better.
I have taken a bulkhead out of my last project but the truck was stripped of everything before the bulkhead came off, the wiring harness wasn't saved etc etc so this is a whole new ball game!
Old July 9th, 2014, 11:50 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I will document the process and post here as I go along. I'm currently trying to create a master list of all the seals, grommets, bolts, nuts etc that will need to be replaced so I have it all ready for re-assembly.
That would be awesome and I am sure a lot of people would benefit from it. Thanks!
