Bulkhead T/door post galvanizing question - Defender Source
Old January 18th, 2014, 04:34 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
I'm prepping my bulkheads for galvanizing and I was wondering if you need to remove the tposts and if they need to removed is there a trick to get them out.
Also, do I need to drill out the rivnuts before taking it to the galvanizer.
Thanks.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old January 18th, 2014, 04:42 PM
You do want to remove the t posts and galvanize them too. They are not hard to get out. A stud plate at the front. Two bolts to the roof. Rivets at the body. Floor bolts. I would leave the rivnuts in and then drill and tap them out after galvanizing.
Old January 18th, 2014, 06:21 PM
grnrvrs's Avatar
grnrvrs
Paul
88
X2 definitely galv the t pillars too.
1970 SIIA 88, Sold
Old January 18th, 2014, 07:15 PM
This is for your 90? They don't call them t-posts but I assume you mean the piece that runs between the bulkhead and the tub parallel to the frame rails. It's just a few bolts and they come off easy. Except you'd have already removed them to get the body off the frame so I am not sure this is what you mean!
I'd remove the rivnuts because at best they will come out in the process and at worst you'll have a nasty blob there afterwards.
Originally Posted by pendy
I'm here for the D's
Old January 18th, 2014, 11:28 PM
lordhelemt's Avatar
lordhelemt
Paul
I'm referring to the posts that attach the bulkhead to the frame and the doors mount too.
Old January 18th, 2014, 11:32 PM
Those are part of the bulkhead. It's all one piece.
Old January 18th, 2014, 11:34 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I am trying zinc plating on my bulkhead and T posts for the 110.
Semper Fi!
Old January 18th, 2014, 11:39 PM
lordhelemt's Avatar
lordhelemt
Paul
No wonder I wasn't able to remove them :-)
Old January 19th, 2014, 09:37 AM
Do you have any pictures? There really shouldn't have been anything to give you the idea they were in fact removable.
Old January 19th, 2014, 06:50 PM
lordhelemt's Avatar
lordhelemt
Paul
Pic of the post I'm referring too
Old January 20th, 2014, 09:28 AM
Yup, just do your mods and take it to the galvanizer and ask them to strip it first. At the last galvanizer I used it was about the same price as the actual galvy, and came out to about $1/lb for strip and dip. I expect this place to be the same or cheaper based on Doug's experience.
Old January 20th, 2014, 02:37 PM
lordhelemt's Avatar
lordhelemt
Paul
I thought I needed to bring it to the galvanizers prepped and ready to go. What's the name of the place that will strip it for you? I'd rather just take it to one place and be done w/ it.
Old January 20th, 2014, 06:57 PM
It's the same place. I'll PM you my number and can explain better.
Old January 20th, 2014, 07:19 PM
or you can contact me and I'll tell you how it works since I;m the only one to have used those guys so far
Old January 22nd, 2014, 08:38 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Doug, you the man
door, galvanizing
Stupid question: bulkhead vents jafir Defender Technical Discussions 2 May 25th, 2013 08:30 PM
bulkhead repair panel question jayz Defender Technical Discussions 2 October 15th, 2012 04:36 PM
Upper Bulkhead Repair Question isleofbones Defender Technical Discussions 4 April 13th, 2011 03:18 AM
Galvanizing the bulkhead D90user Series Technical Discussions 16 September 30th, 2010 10:13 AM
Galvanizing the bulkhead? crobinson Defender Technical Discussions 2 December 30th, 2005 01:34 PM
