Bulkhead Swap - Defender Source
Old July 26th, 2005, 08:31 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Bulkhead Swap
I have rust o plenty, some (much) worse than others on the bulkhead/firewall of my 110. As this is my daily driver, I cannot tolerate much downtime. As a result, I am considering purchasing a new bulkhead and swapping out, rather then removing, repairing, repainting and reistalling. My questions are:
1. How difficult is this? (I already plan to have the top and doors off for some other rust repair - I dont anticipate the top and doors preventing me from driving)
2. Are there any gotchas that I should look out for when replacing and are there parts that should be replaced along the way, rather than re-used?
Thanks in advance,
Matt
Old July 26th, 2005, 09:37 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
That is the best bet. Then you can take it off all in one and remove things piece by piece and install them on the new bulkhead whick will be on the truck already. I would check the heater box while it is off. Might be a good time to do the matrix or the entire box. Also, how old it the master cylinder for the clutch?? You will need to remove the front fenders so if you have things to do on the motor, now will be the time. Here are some pics from my project http://www.defendersource.com/forum/...1&page=5&pp=15
Legend in My Own Mind.
Bulkhead swap ? Uncle Douglas The Flea Market 6 November 13th, 2008 08:32 PM
Bulkhead Rust TurkD90 Defender Technical Discussions 4 May 14th, 2005 05:06 AM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
