Bulkhead Swap - Defender Source
Old April 19th, 2013, 11:51 AM
61rover's Avatar
61rover
John Crouse
Bulkhead Swap
So my original plan was to swap the frame and bulkhead on my 110 at the same time. That isn't going to be possible for a number of reasons. So I'm going to have to do the bulkhead first. Not my prefered path, but that's where I'm at.
My question is this. In order to minimize the downtime of my truck, what prework to the replacement bulkhead do you recommend? (It will be galvanized and painted) I can't afford to build it up completely with new parts, but what makes sense? What key parts won't be reusable? Anything that should be replaced regardless of condition while it is apart?
Old April 19th, 2013, 11:57 AM
Big rivnuts for steering and heater mount. Small rivnut for dash mount. All the small plastic plugs. New big bolts through frame. Bulkhead to fender bolts if rusty. Clean out galvanizing holes and square them off. Brake and clutch pedal gaskets. Windscreen to bulkhead gasket. Assortments of stainless steel screws. M5 bolts for bulkhead (not common to find and annoying size). Stud plates from bulkhead to sills (these are usually bad in my experience).
Old April 19th, 2013, 12:07 PM
61rover's Avatar
61rover
John Crouse
No I have an OEM replacement for the NAS D110.
Old April 19th, 2013, 12:08 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
as above, but clean/ retap the rivnuts before painting, see bill's post on using map gas torch, it is hella getting a 8mm tap stuck in a rivnut afterwards. ask me how I know.
For the seals of the brake/clutch peddle boxes and steering bracket, go to our local Biglots/Homedepot and get a roll of the foam diamond tread worshop mat, its about $16 you well have enough to do the load bed of the tub and some for the floor in front of your work bench. As one seal from a Rover dealer is the same price as the whole roll.
Just my 2 pence worth
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Chassis /bulkhead swap DonFromWhitby Defender Technical Discussions 27 April 12th, 2013 11:09 PM
Bulkhead swap ? Uncle Douglas The Flea Market 6 November 13th, 2008 08:32 PM
Bulkhead Swap mattarm Defender Technical Discussions 1 July 26th, 2005 09:37 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
