Bulkhead Repair - Defender Source
Old January 9th, 2016, 12:01 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Bulkhead Repair
I recently noticed a small rust hole on the inside of the bulkhead. It is located on the left upper side beside the bracket / bolt that retains the windshield. The outside of the bulkhead appears fine. My question is at what point do you repair a bulkhead? I am well aware of a small project turning into a much larger one. I am looking at is the repair worth the time, money, and down time (daily driver) or do I save for a knew bulkhead for a couple of years down the road? I have sprayed the cavity with a rust converter until I figure out my plan.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old January 9th, 2016, 12:06 PM
bjf's Avatar
bjf
barry f
94 ST #395
How did that get missed when you did a full color change?
Old January 9th, 2016, 12:10 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Not sure to be honest. Just noticed the rust colored drip on the white and poked it with a screw driver.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old January 9th, 2016, 12:16 PM
bjf's Avatar
bjf
barry f
94 ST #395
So the hole wasn't there until you pushed through?
Wonder if water was pooling there and rust just happened. I know most stuff from New Zealand is rust free.
Old January 9th, 2016, 12:29 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
So the hole wasn't there until you pushed through? Wonder if water was pooling there and rust just happened. I know most stuff from New Zealand is rust free.
That it was I am thinking. I was scraping the rust flakes with a screw driver when it went through. Not really a push. After pulling the truck apart I found the bulkhead to have not been as pristine as I thought. It had previous repairs.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old January 9th, 2016, 12:40 PM
bjf's Avatar
bjf
barry f
94 ST #395
You have done so much work to that truck I wouldn't let the rust sit. Have it repaired now. Hopefully it isn't much bigger than the hole.
Cut the cancer out.
Old January 9th, 2016, 12:42 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
You have done so much work to that truck I wouldn't let the rust sit. Have it repaired now. Hopefully it isn't much bigger than the hole. Cut the cancer out.
I think that will be my route once I sell the 109.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old January 9th, 2016, 02:04 PM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
Unfortunately to do it right the windscreen has to come out. It is usually just as bad under the seal. In my experience it's rarely just isolated to just one side so check the other side real good if you are going to the trouble of removing windscreen.
Patches are for Pirates and pants, not a bulkhead and chassis!
Old January 9th, 2016, 03:07 PM
And down the slippery repair slope we go....
Old January 9th, 2016, 04:45 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Bummer. It is so rarely just one spot...
Removing LH wing / Fender on '83 for bulkhead footwell repair... turbodave Defender Technical Discussions 5 May 25th, 2009 04:16 PM
Bulkhead Repair Panel SafariHP The Vendors Loft 4 February 15th, 2009 07:55 AM
Drivers side bulkhead footwell repair panel for left hand drive D-90 Tyler Wirken Wanted 4 September 25th, 2008 12:26 AM
Bulkhead LH footwell repair panel? turbodave Defender Technical Discussions 1 August 22nd, 2008 03:03 PM
Bulkhead repair 61rover Defender Technical Discussions 1 May 19th, 2008 03:33 PM
» Defender Registry
Barbara
curry
TOAD
SaltyDog
Add your Defender
