Bulkhead Repair - Defender Source
Old February 17th, 2009, 01:10 PM
bjf's Avatar
bjf
barry f
94 ST #395
Bulkhead Repair
http://www.paddockspares.com/pp/DEFE...anel_-_RH.html
Has anyone ever used this? Do you cut out the old steel?
Old February 17th, 2009, 05:58 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Its usually rotted away and yes I believe you do have to cut before welding to make it flush.
Pat
Kirk Lazarus, Tropic Thunder
Old February 17th, 2009, 06:02 PM
bjf's Avatar
bjf
barry f
94 ST #395
it looks like an easier way to fix it
Removing LH wing / Fender on '83 for bulkhead footwell repair... turbodave Defender Technical Discussions 5 May 25th, 2009 04:16 PM
Bulkhead Repair Panel SafariHP The Vendors Loft 4 February 15th, 2009 07:55 AM
Bulkhead LH footwell repair panel? turbodave Defender Technical Discussions 1 August 22nd, 2008 03:03 PM
Bulkhead repair 61rover Defender Technical Discussions 1 May 19th, 2008 03:33 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
