bulkhead removal question - Defender Source
Old January 22nd, 2015, 09:37 PM
defender1844
Amit Likhyani
My shop is getting close to actually lifting my old bulkhead off and swapping it for the new straight one I bought a little while back. One question: is there a trick to routing the engine harness through? There doesn't seem to be a plug or any easy way to break it. It seems the tedious brute force way of pushing it through is the only option. Just wanted to make sure.
Name:	2015-01-22 15.38.14.jpg
Old January 22nd, 2015, 09:39 PM
Nope.
Old January 22nd, 2015, 09:40 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
You have to unplug from the engine bay side and snake it into the cab.
Old January 22nd, 2015, 09:43 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Push the rubber grommet out then push small groups of cables out and not everything at once. Start with the smallest connectors and work to the largest ones last. It's actually not too bad.
Old January 22nd, 2015, 09:58 PM
never had a problem
Old January 22nd, 2015, 09:59 PM
defender1844
Amit Likhyani
thanks guys. Can't get over how helpful this board is.
Old January 22nd, 2015, 10:00 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
LMFAO! Good luck boss...
Old January 22nd, 2015, 11:44 PM
It is really not hard at all to get the wiring through the bulkhead. Just label everything well and you will be fine. Wiring the inside of the dash is much worse (particularly on a NAS 110) than the engine, even on a NAS EFI truck.
Old January 23rd, 2015, 09:25 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
I agree, I was laughing bc the lack of real info to help, and the OP's sarcasm... You are 100% right take your time and label everything
Old January 23rd, 2015, 10:14 AM
Brute force is only required if you try to push it through without removing the grommet first. The holes are actually pretty big.
Hope that helps.
Cigar Lighter Removal and Rear Wiper Switch Removal isleofbones Defender Technical Discussions 6 April 13th, 2013 08:02 PM
two bulkhead bolts...removal question Gkase Defender Technical Discussions 7 November 3rd, 2010 05:33 PM
Bulkhead removal bar Jase Misc. Chit-Chat 2 June 9th, 2006 11:49 PM
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
