bulkhead removal - Defender Source
Old April 11th, 2009, 01:00 PM
ditskovich's Avatar
ditskovich
dmitry
Range Rover Sport 2013
bulkhead removal
how hard to remove bulkhead?
How many bolts, and where,
The best way to keep wires untangled
I have a hard time unscrewing two big bolts on a side
ID:	18732   Click image for larger version
Old April 11th, 2009, 01:29 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
not hard... you are there.... the 2 large side bolts. then the support brackets on either foot well with 2 small bolts each.. Then lift it off. I would soak the large outer bolts with WD-40. You might have to bang them out.
Legend in My Own Mind.
Old April 11th, 2009, 07:55 PM
Disconnect all the wires from the motor (including the ground at the back). Disconnect the brake lines and clutch line. Also disconnect the speedo cable at the junction box. The bulkead is held on by at least six bolts. The two screw headed ones in each footwell and the two big ones that go through the outrigger. Once you are to the place you are now, you are doing really well and it should not take more than an hour to get it off.
If you look in the projects section, you can see I just did this
Old April 13th, 2009, 12:41 AM
ditskovich's Avatar
ditskovich
dmitry
it looks like two on a side are hardest to remove.
no luck.
may be because frame is bent
Old April 13th, 2009, 12:47 AM
no luck.
No, that is normal. The fuckers rust in place. Get a breaker bar and a pipe on the end and break the bolts. If that fails you can take a sawzall and cut them where the washer is between the bulkhead and the frame.
The one side on mine I broke, then sawzalled and then hit with a sledge hammer to free it up. The other side just slid out.
See annotated picture for more detailed instructions.
Old April 13th, 2009, 08:20 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
LOL.. Great Pic
Old April 13th, 2009, 03:58 PM
ditskovich's Avatar
ditskovich
dmitry
frame parts
help me to move engine and transmition to a new frame and you can have it
Old April 13th, 2009, 04:11 PM
I would love to but I am swamped. There are a lot of folks in your area, I bet one of them has a hoist you can borrow. Ren Ching, cgalpin, Doug Crowther etc. Or just rent one, it is really easy to move stuff over between frames.
Old April 13th, 2009, 04:44 PM
dmitry you can come and borrow the hoist any time. shouldn't be a problem to move it to your place. gotta bring you that bumper anyway. give me a call if you still have my number.
rgrds
d
Old April 13th, 2009, 04:47 PM
Dave, hack me off that crossmember and bring it with the roof sides
Old April 13th, 2009, 04:50 PM
hey, I might need it
actually mine is good for now...but needs some patching soon or it won't be...
Old April 13th, 2009, 04:58 PM
Better than mine!
http://www.defendersource.com/forum/...chmentid=18755
Old April 13th, 2009, 05:18 PM
Dmity, what's wrong with the frame? D90 I assume?
Old April 13th, 2009, 05:23 PM
it is severely bent at the front, parallelogrammed and the right side rail is pushed out about where the trans mount is. it was a pretty hard hit. maybe salvageable but the new frame will make life a whole whole lot easier.
we should all converge on dmitry's place some day and get the engine, trans, and axles over onto the new frame. an easy day with enough hands available.
Old April 13th, 2009, 05:28 PM
Free time isn't my friend right now, but with sufficient advanced notice, I'm game.
Old April 13th, 2009, 05:46 PM
ditskovich's Avatar
ditskovich
dmitry
would grill and beer make it more desirable?
I don't mind to have MD and VA crowd over for a fast finish and advise, especially if I have no idea what I am doing.
My grill, usually, is something to remember.
What is the best way to get rid of rust, and what to use to paint it over?
ID:	18783   Click image for larger version
Old April 13th, 2009, 06:03 PM
Wire wheel on a big angle grinder, then spray with rust converter, then epoxy primer, then appliance epoxy black paint.
Some people say POR 15, but I prefer my method.
MUD UK Bulkhead removal bar Ren Ching Smaller Projects 4 February 6th, 2009 01:24 PM
Frozen bulkhead bolts removal suggestions? Tyler Wirken Defender Technical Discussions 12 July 23rd, 2008 04:29 PM
Bulkhead removal bar Jase Misc. Chit-Chat 2 June 9th, 2006 11:49 PM
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
