Bulkhead modifications for 300tdi - Defender Source
Old February 24th, 2007, 03:40 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I have a bulkhead off a NAS defender that I am using for the D90 300tdi I'm building. Today, I got the air intake hose that goes from the air cleaner to the turbo (air cleaner hasn't arrived yet). It appears the bracket on the bulkhead for the V8 air cleaner is in the way. Does that need to be cut off? How much?
Old February 24th, 2007, 04:32 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Yes, remove the entire thing. IF you have a spot weld cutter, cutthe spotwelds and remove it or grind the spot welds...
Legend in My Own Mind.
Old February 24th, 2007, 04:46 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Gives me an excuse to get a spot weld cutter. Thanks.
Old February 24th, 2007, 05:09 PM
I used a spot weld cutter from eastwood that doesnt require drilling a pilot hole all the way through the underlying panel.
Also, you will need to fabricate and angle bracket for the clutch hose which will mount to the passenger footwell.
Old February 24th, 2007, 06:11 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
http://www.eastwoodco.com/ lol I was just posting the same thing.
Do you have a new engine/kit? IF so, it comes with the clutch hose bracket. If not, very easy to make.
Old February 24th, 2007, 10:13 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I already ordered the part from Eastwood and the bracket is also fabricated Thanks.
Old February 25th, 2007, 11:16 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Good luck. let me know if you need any more questions answered.
300tdi, mod, tdi
Bulkhead Rust TurkD90 Defender Technical Discussions 4 May 14th, 2005 05:06 AM
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
Bulkhead Questions JimC Defender Technical Discussions 19 October 27th, 2004 01:00 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
