Bulkhead Heat - Defender Source
Old July 7th, 2009, 01:06 PM
bjf's Avatar
bjf
barry f
94 ST #395
Bulkhead Heat
I have noticed in my 110 my bulkhead is extremely hot. As I drive my toes get hot and I reached down where the pedals are and the metal is hot to the touch. Is this normal? I never noticed it in my 90. I dont have kick panels in right now. Also my AC stopped blowing cold so I have no clue if this is related.
Old July 7th, 2009, 01:11 PM
Could be clogged cats.
Ron
Old July 7th, 2009, 01:12 PM
bjf's Avatar
bjf
barry f
94 ST #395
Would they make a weird sound or anything? My CAts are fairly new
Old July 7th, 2009, 01:23 PM
Marbles in a can.
Old July 7th, 2009, 01:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
yeah that I dont have. Anything else?
Old July 7th, 2009, 01:35 PM
Out of tune or out of time can cause excess fuel to end up in the exhuast where it is burned in the cats causing excess heat. Or, you know, it could be normal and you are crazy.
Old July 7th, 2009, 01:40 PM
bjf's Avatar
bjf
barry f
94 ST #395
clearly crazy
Anyone else have a hot bulkhead?
Old July 7th, 2009, 01:53 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
One of my buddies and I bought '93 NAS 110's new. He ended up putting ceramic coating on his floorboard and bulkhead because of the heat - I never thought it was that bad on mine.
Old July 7th, 2009, 01:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah I was going to dynamat the area but wasnt sure it would do anything.
Old July 7th, 2009, 01:59 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
I would not dynamat if it gets that hot, it will just melt and slide around. You want to do a few things, get an IR themometer and check the temperature of the exhaust running under it to see if it is unusually high. You can put thermal insulation on the outside, add heat-shielding etc but knowing if there is a problem is the best first thing.. if you are afterburning it is probably something you want to know because unlike on a jet, it doesn't make the Defender any faster
Old July 7th, 2009, 02:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
why cant anything ever be easy
Old July 7th, 2009, 03:10 PM
61rover's Avatar
61rover
John Crouse
Bulkhead heat
The heat helps clear out the rainwater that is flowing in after each storm.
Old July 7th, 2009, 03:23 PM
bjf's Avatar
bjf
barry f
94 ST #395
so true
I just want to know if it is normal
Old July 7th, 2009, 07:29 PM
ditch the cats and header wrap the y-pipe. I am going to do this one day.
Old July 7th, 2009, 07:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
would love a full NRP exhaust set up. Anyone giving one away?
HA
Old July 7th, 2009, 08:22 PM
Doesn't NRP still suck?
Old July 7th, 2009, 08:26 PM
NRP reportedly has not sucked for a few years (finally used SS for welds), but that is just rumor.
PS it is still light out JimC, get back to work on the truck.
Old July 7th, 2009, 09:40 PM
JRW's Avatar
JRW
94 D90 ST #1247
I had a similar issue with my Defender. One thing you haven't mentioned which I experienced is an increase in the temperature when in motion.
Turns out there is a plate or cover missing in the firewall which was letting heated air from the engine compartment come into the pedal box. I can't remember exactly where my guy said it was, but I remember it is a part which sometimes gets left off when they work on the clutch.
When I first drove the Defender with flip-flops, I swore my toes were going to catch fire...
Old July 8th, 2009, 09:42 AM
bjf's Avatar
bjf
barry f
94 ST #395
Ah do you know the part?
Old July 8th, 2009, 01:42 PM
JRW's Avatar
JRW
94 D90 ST #1247
I have to take in my Defender tomorrow, so I will ask.
Bulkhead Rust TurkD90 Defender Technical Discussions 4 May 14th, 2005 05:06 AM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
Bulkhead Questions JimC Defender Technical Discussions 19 October 27th, 2004 01:00 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
