Bulkhead Alignment - Defender Source
Old March 25th, 2016, 09:20 AM
Grover's Avatar
Grover
Question Bulkhead Alignment
I'm currently dressing up my two front doors and noticed my bulkhead out of alignment. The top of the bulkhead leans in 3/16" towards the rear tub. My question is, do the front wings need to be removed to align the bulkhead?
Btw, this is for a 1995 D90 NAS ST
Cheers...
Old March 25th, 2016, 01:36 PM
I guess my first question would be "has the tub been off? Just curious what caused the I'll-alignment.
If I wanted to lean the bulkhead, I would at least remove the bolts where the fenders bolt to the a-pillar at the outsides of the foot wells (frome the engine side). That might give you enough free play once you loosen the diagonal brackets that brace the bulkhead to the frame.
Old March 25th, 2016, 02:27 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
This is a timely question...
I just installed the bulkhead last night.
This is a ST as well.
So I just made it plumb as possible.
Jim,what is the best method for tub-door-bulkhead alignment when everything has been off??
Rent my
Old March 25th, 2016, 03:12 PM
Grover's Avatar
Grover
The tub has never been removed. When the doors where off, I measured the horizontal distance from the bulkhead to the tub, the bulkhead is leaned in towards the tub evenly on both sides by 3/16"
I want to know what I need to loosen to get play to straighten it.
I'm guess along with the wings, I need to loosen the a-piller roll cage bolts, the gussets near the footwells.
Old March 25th, 2016, 03:48 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Hey Mike, I'm curious...
how many of these shims do you have under the bulkhead support on the frame?
Is it the same amount on both sides?
Rent my
Old March 25th, 2016, 04:48 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
No, you do not have to remove the front clip to realign your bulkhead. Yes you need to loosen all the bolts to get the play you will need to align it correctly. Tow straps will be your friend and go beyond where it needs to be because it will spring back... Good luck
Old March 25th, 2016, 06:13 PM
Grover's Avatar
Grover
My fear is putting the wings in a bind when pulling the top of the bulkhead forward.
Old March 26th, 2016, 07:59 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
with the hard top I leave everything loose and make sure the top and doors align pretty well. I check the gaps and go for what looks the best. With the soft top you would have the door alignment to check But I may check the top alignment too. 3/16 of an inch doesn't sound like much.
Land Rover 110
Old March 26th, 2016, 09:34 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
you're taking about less then a 1/4"... If everything is loose then it shouldn't be an issue. And more then likely each side is different...
Old March 26th, 2016, 11:10 AM
I'm also interested in hearing about the recommended technique to set the bulkhead from scratch to get the doors (and I guess everything else) to sign up well.
Originally Posted by pendy
I'm here for the D's
Old March 26th, 2016, 07:09 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
give me a ring... To much to write down
Old March 26th, 2016, 07:14 PM
RamblerRob
Rob Apps
1967 series 2a 109 NADA
I'd like to hear the whole story about aligning from scratch if anyone wants to take the time to write up a guide. I'm not there, or even close on my own project but will be at some point.... I hope
Old March 26th, 2016, 08:54 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
The quick and nasty that I have learned, there might be other ways as well... I always start by mounting the two outer bolts on the rear tub on the rear crossmember loose. Then I put on one on each of the front tub mounts, loose as well. Next step is to mount the bulkhead, I typically only mount the two main outrigger bolts to start(loose of course). A trick I learned from Bill Adams is to run a string from the bulk head just above the curve to the back of the tub on the curve as well. This will allow you to center the tub and raise or lower it so the sting will kiss the front of the tub. Once the rear tub is close, I would zap down the four bolts to secure the tub. This will allow you to pull measurements on the doors for the bulkhead.
------ Follow up post added March 26th, 2016 09:02 PM ------
Once the tub is secured pull measurements from the rear of the tub to the bulkhead at the bottom and the top. I could be wrong but I believe it's 34.5" from side to side. Once the bulkhead is square to the rear tube tighten down and use what ever shims you need to secure the front bulkhead brackets. I like to repeat the string trick to make sure my wings are square as well, running them side to side and front to back.
alignment
Front Door/Rear Quarter Panel Alignment Grover Defender Technical Discussions 12 August 7th, 2008 07:22 AM
Pitman arm alignment cgalpin Defender Technical Discussions 12 December 11th, 2007 06:33 PM
bonnet / hood alignment jcasteel Defender Technical Discussions 5 December 28th, 2005 12:54 PM
Steering alignment kellymoe Defender Technical Discussions 10 November 19th, 2004 12:23 PM
Bonnet / Hood alignment jcasteel Defender Technical Discussions 1 November 6th, 2004 10:07 PM
