bulkead corrosion near windscreen hinge - Defender Source
Old March 7th, 2004, 09:01 PM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
Unfortunately, I just discovered corrsion under the paint right around the passenger side windscreen frame hinge. It apears as though I need to pull the windscreen off/down to get at the spot and address it quickly since it is pretty small. My RN manual does not cover the body of the D90 hardley at all. Any suggestions on how to get the windscreen frame to remove or fold down? As always, I appreciate everyones input!
Jeff
Pain is weakness leaving the body
Old March 7th, 2004, 09:49 PM
mattdh's Avatar
mattdh
Matt Hurst
jeff if your talk about the hiinge that is about an inch wide and about 3 or 4 inches long. its not really a hinge, it has 3 bolts holding that so called hinge on.you can un bolt the three bolts and that so called hige just comes off you dont have to worry aqbout moving the windscreen. let me know if this is what you are talking about
Old March 8th, 2004, 01:54 PM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
Matt, Thanks a bunch, this sounds exactly like what I am referring to. It is exactly as you describe. I presumed it was a hinge since I have seen non-NAS versions with the windscreen down. This sounds like it will be easier than I expected. Thanks again!
Door Hinge Options... CDN38 Defender Technical Discussions 2 February 4th, 2005 12:29 PM
Door hinge screw replacements - guidance paulb Defender Technical Discussions 4 September 22nd, 2004 06:51 AM
Door hinge pin mspell Defender Technical Discussions 1 September 8th, 2004 04:14 PM
Windscreen ideas Mike Hippert Misc. Chit-Chat 40 July 9th, 2004 02:38 PM
Rear Door Hinge Replacement Rob Defender Technical Discussions 2 January 21st, 2004 01:26 PM
