Building the Ultimate rear cross member! - Defender Source
Old August 17th, 2011, 11:30 AM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
https://picasaweb.google.com/1104768...CJTy-oHr8LWffQ
This is a cross member that I am building for my 90 since every thing out there does not suit my needs or wants. It is made out of 3x6x 3/16 thick rectanglualr steel. It is to be used as a air resevoir. and has jacking points for the Highlift jack attachment.
This is a prototype so there will probably be modifications.
I am thinking about building these for resale if the cost is productive and there is enough interest.
P.S. And Jonathan i.e. [Wolf Fabrications] I will be your checking copy rights. LOL
Old August 17th, 2011, 11:47 AM
jijalicious
Jiman Khosravan
'94 D90
Ummm... can we switch garages for like a month?!?!? maybe 5?!?!
~Jij
Old August 17th, 2011, 01:16 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Looks strangely familiar...
http://www.defendersource.com/forum/...eferrerid=5244
Old August 17th, 2011, 01:28 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Originally Posted by RiftRover View Post
Well, it's not like there are 10 different ways to do it.
Both look good.
- Charles Eames
Old August 17th, 2011, 01:33 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
Thats way to funny I never saw that post.LMAO
Great minds think alike
Old August 17th, 2011, 01:44 PM
This is definitely the way to do it! Looking good.
Originally Posted by pendy
I'm here for the D's
Old August 17th, 2011, 01:53 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I did something very similar. And I thought I was the first. Oh well.
Old August 17th, 2011, 02:54 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Just finishing up a similar one on my 101
Name:	New rear cross member2.jpg
Chris "V"
Old August 17th, 2011, 03:43 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
I will take one + that much garage space. Living in a downtown style townhome blows for cool projects like this.
Old August 17th, 2011, 06:42 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Too late, already sold the rights to a sweatshop in China!
You'll need to TIG all the seams if you really want it to hold air, otherwise you'll battle air leaks with the MIG all day. Or obviously make sure you get really good welds on clean steel, but you know that.
Semper Fi!
Old August 17th, 2011, 06:54 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
My home made version on my 110
Name:	2011-04-14 19.12.40.jpg
Old August 17th, 2011, 11:14 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Agreed! Not sure why no one is selling a replacement like this already. If I had the time or the resources I would do it...
Old August 17th, 2011, 11:58 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
I think i have the resorces. One concern is that the average Joe will be intimidated by cutting their frame. Or finding someone who can.
Old August 18th, 2011, 05:08 AM
reb78
REB
Land Rover 110
I think my worry if making them for others would be the variability in the different chassis'. Knowing land rover tolerances, where you place your extensions may need to be tailored to each vehicle to get a decent fit. Perhaps it would be worth having a measure up of several vehicles to see if there is any variability there.
Having said that, looks like a nice job. I have a folded C section of 5mm steel that i have replaced my crossmember with, its ok, but yours looks much neater and i'd go that way if i were going to do it again. Its a new galv chassis for me next time anything serious needs doing on my chassis though!
Old August 18th, 2011, 06:42 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I doubt even Doug Richardson, who built his Demolition Bumper in the '70's, was the first. Though his was used to hold oil for oil changes.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 18th, 2011, 07:49 AM
I don't think this is an issue. If you are replacing your cross member you have to do this anyway.
Perhaps the answer is a kit with the bumper and the attachment brackets not welded on, allowing for adjustment during install.
Old August 18th, 2011, 08:25 AM
Hammertime's Avatar
Hammertime
Dana Hammersley
Again I thought of that also. Only because we do a expedition up in to Canada with Lucky 8. There is always someone needing extra oil or something and that would be a good way to carry it. Plus it goes with my personality of try to be prepared. Next on the list is a On board welder.
Old August 18th, 2011, 09:02 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I find it hard to believe that you and Jill ever run short on storage space!
Old August 18th, 2011, 09:25 AM
I don't think any of these are new ideas. I am in general a fan of this sort of thing, but as I get older I start thinking of these things as being unwanted complexity and failure points. I'll give an example. A friend built a buggy to compete in the KOH with and thought it was a clever idea to use his cage tubing as a coolant line from the engine to his rear mounted radiator. I thought so too. Until he hit a tree at speed, cracked a weld and was out of the race. If it was good old hose he could have patched it and continued on.
Old August 18th, 2011, 10:14 AM
jijalicious
Jiman Khosravan
'94 D90
Yeah, but that's a hell of an idea!
rear cross member ron Wanted 0 May 15th, 2009 11:09 PM
rear cross member replacement question Cirbo Defender Technical Discussions 16 May 25th, 2008 01:04 PM
rear cross member 1of40 Defender Technical Discussions 5 December 1st, 2005 11:48 AM
New Safari Gard 3-link cross member Davis For Sale - Parts 2 July 4th, 2004 05:00 AM
