Building the Ultimate rear cross member! - Page 2 - Defender Source
Old August 18th, 2011, 10:46 AM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
If you do really want to use the rear cross member for air, oil, or any other liquid reserves , make sure the inside of the tube is thoroughly coated with a sealer (fuel tank sealers are good, I poured in POR15 and rolled the tubing around to coat all surfaces. Normal compressed air unlike Nitrogen contains a lot of moisture and it will rust out the inside of the tube (take a look at some of the old stand up commercial air compressor drain valves some time (usually filled with rusty water) and I have to tell you to get a perfectly air tight weld with a mig is almost impossible (but the POR15 could help seal these weld joints also)
Chris "V"
Old August 18th, 2011, 05:58 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Originally Posted by cgalpin View Post
as I get older I start thinking of these things as being unwanted complexity and failure points.
It depends. Using it for something "mission critical", IMO, is evidence of not thinking things through. But using it for compressed air storage (I assume for lockers or air tools) or oil for oil changes while traveling would just be an inconvenience if they failed. Not a show stopper at all.
So yeah, using it as part of your cooling system is pretty dumb IMO.
Actually I've welded a number of pressure vessels using MIG. On the other hand, I was an ASME certified pipe weldor at the time. If you have good technique it's easier than stick.
That said, for most people I would tend to agree.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 7th, 2011, 09:44 AM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Dana, Where are you with fabricating for others?
Old September 11th, 2011, 10:37 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Don't forget a drain valve to drain moisture if using for compressed air.
Old September 12th, 2011, 08:12 PM
Frank84
Frank Battersby
95 D90
That's looking great Dana!
'95 Soft Top
'89 Classic Tdi
rear cross member ron Wanted 0 May 15th, 2009 11:09 PM
rear cross member replacement question Cirbo Defender Technical Discussions 16 May 25th, 2008 01:04 PM
rear cross member 1of40 Defender Technical Discussions 5 December 1st, 2005 11:48 AM
New Safari Gard 3-link cross member Davis For Sale - Parts 2 July 4th, 2004 05:00 AM
