Building my own snorkel - - Defender Source
Old March 1st, 2006, 06:45 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I'm building my own version of the snorkel I saw on the Ex-tec website and using an Engineaire precleaner. I'm using 3" aluminum tubing and have the snorkel tube ready to be powdercoated satin black. I just need to fabricate an upper mount that will clamp around the rain gutter on the roof and provide a tab for the circle clamp that goes around the tube.
I may wind up building my own clamp but I wondered if any of you guys had any ideas for something that was more or less off the shelf? Here's a picture of the snorkel so far....
Old March 1st, 2006, 11:39 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
With or without roll cage?
Old March 2nd, 2006, 07:17 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
No cage - ROW truck
Old March 2nd, 2006, 01:28 PM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
Nice design. It's most likely the perspective of the image but are you sure that the door will open correctly w/out the mirror bumping into the snorkel?
Old March 3rd, 2006, 07:17 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Finished up my snorkel this evening - it turned out really well - no clearance issues and from the drivers seat you only see the front 3/8" of the tube. The passenger gets only a glimpse of the trailing edge of the tube. I powder coated the aluminum tube using a friend of mines eastwood do-it-yourself powder coating kit - the trick was figuring out how to cure something that wouldn't fit in the oven. We wound up doing it in two stages - painted the lower half and then turned it around and cooked the upper section. Made an upper mount from a piece of stainless angle and fastened it through the rain gutter on the roof.
The total cost was under $180 - helps to have a handy scrap barrel with sections of 3" aluminum tubing and a friend who is an absolute wizard with a tig welder available. Most of the cost was in the Engineaire precleaner - neat piece - a bit extravagant but the rest of the snorkel was costing me so little that I splurged a bit.
ID:	5173   Click image for larger version
Old March 4th, 2006, 12:55 PM
Do you off road that thing? I would not like it sticking out past the body. If it were my truck it would be ripped off on the first trip.
Old March 4th, 2006, 02:53 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
It doesn't stick out past the flares and the top of teh precleaner is below the roof line - with the air intake in the side of the fender you have to work with what is there - besides I've been driving Land Rovers for over thirty years - I'm reasonably good at not hitting stuff....
Old March 6th, 2006, 01:39 PM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
Looks sweet. Nice job.
snorkel
snorkel useful? David-D Defender Technical Discussions 20 November 18th, 2005 11:16 AM
Mantec Snorkel Install Question ronward Defender Technical Discussions 2 April 1st, 2005 08:16 AM
Cheapest place to buy Tuffy console, Mantec snorkel Chris Cox Defender Technical Discussions 7 March 14th, 2005 09:21 PM
Genuine Land Rover Snorkel STC5065 lrnasd90 For Sale - Parts 15 September 28th, 2004 06:28 PM
Snorkel Cap? Quimbola Defender Technical Discussions 7 November 17th, 2003 12:08 PM
