Build Spec Sheet - Defender Source
Old February 21st, 2013, 12:10 AM
Oannes's Avatar
Oannes
Aaron
1997 NAS D90 (Original Dream Car)
Build Spec Sheet
I have done a search and cant seem to find anything like this?
Has anyone built an excel spreadsheet for a new or existing build? Getting ready to start a new project and I normally would put together a complete sheet to estimate time, budget, parts needed, etc...
Any help or direction would be great.
Aaron
We make a living by what we get, we make a life by what we give. Sir Winston Churchill
1984 Defender 130 (In the middle of build)
1988 Defender 110 CSW (Original)
1964 Series IIa 109 5 door (South Africa in a thousand pieces)
1973 Series II 109 5 door (Australia)
1997 NAS Defender 90 (Already sold so)
2013 Chevrolet 2500HD (work horse)
Old February 21st, 2013, 12:21 AM
grnrvrs's Avatar
grnrvrs
Paul
88
Are you talking about for a rebuild? If so, I can't imagine how you could accurately estimate the parts required without either completely disassembling first or assuming that everything needs to be replaced e.g. a ground up build with all new parts.
1970 SIIA 88, Sold
Old February 21st, 2013, 06:42 AM
Doubt many guys would want to know the true cost of a rebuild.....
Old February 21st, 2013, 07:02 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I tried to keep track of mine, but gave up. I don't really want to know anymore. Plus there are so many other factors in mine like selling off the used parts and changing my mind on parts and upgrades along the way.
You won't know ahead of time and can't judge until you get in to it, plus build hours vary by skill level.
Semper Fi!
Old February 21st, 2013, 08:01 AM
Just triple anything you estimate for time and money. That logic seems to work.
Old February 21st, 2013, 08:04 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Barry had one for his 110 and I have seen a few others. My list is a mess, a work in progress, but here it is if you want to see. Last updated a few months ago and you could add a few thousand $ to this list for new retrim kits, Brownchurch HD Roofrack, etc. Close to $800-900 just for hardware like nuts and bolts. Plus 3 years of my life
1983 Land Rover 110 - $10,000
Transport - 2000
V8 Galvanize chassis - 2950
2008 NTO tub - 4250
OME springs/shocks - 700
OME steering damper - 80
TerraFirma shock towers - 120
Rear tailgate/liftgate - 600
3mm bonnet checker 60 bp
Steering guard 70 bp
heater box seal 14 bp
jump pipe slave clutch 6 bp
12" Tuffy console - 175
10" Tuffy console -185
Swing Away tire carrier - 450
POR15 paint - 100
New Bolts/Nuts - 250
Gas tank - 250
Fuel pump - 30
SS Fuel line - 55
starter - 170
Starter blanket - 20
Clutch - 85
Clutch pressure plate - 125
brake lines - 160
SS brake flex lines - 70
Swivel ball rebuild kit - 37
Clutch Master Cylinder - 37
Pinion Oil Seal - 7
Transfer Lever Boot - 4
2 Clamp Plate - 9
2 U - Bolt - 5
Clutch Flex Hose - 10
Headlight Protectors - 25
4 Bush - Radiator Mounting - 4
2 Filter - Drain Plug - 6
Seal Windscreen - 6
Seal - Air Duct - 10
3 Nut Plate - Rear Body - 30
Gaiter -Self Leveling Unit - 11
Bump stops - 25
Engine/tranny mounts - 30
shovel mount kit - 70
Wing top protector - 110
Rear Step - 50
Header wrap - 25
Gear Lever Knob Red - 8
Yellow 4WD Knob - 8
4 Vent Hinge Pin - 4
Hub Nut Spanner - 9
Headlamp Finisher LH - 19
Headlamp Finisher RH - 19
Gasket Hinge Winscreen - 3
Accelerator/Clutch/Brake pads - 12
Accelerator cable - 3
Prop shaft boot - 13
Power steering reservoir - 14
Power Steering lines rebuilt - 90
Rear bottom floor seal - 8
Buffer - Bonnet/Hood 1.50
10 Stud Anchor 5.90
10 Lock Nut 7.50
1 Bottom Hose 3.5V8 9.95
1 Upper Hose 3.5V8 9.95
Bypass to Inlet Manifold 3.95
Heater to Inlet Manifold 4.95
Thermostat - gasket 1.95
Thermostat 88 Degrees 7.95
Switch Plate 3.25
10 Locknut 3.90
10 Nut - Lokut 3.90
Gaiter - Propshaft 12.95
SD cage 2200.00
X-Brake 380.00
PPG Concept Paint:
-----------------bottom------------------
PPG DCC Trident Green $100.75/quart x 3 quarts = $302.25
DCX61 Hardener 39.60/8oz x 3 = 118.80
DT895 Reducer 22.35/quart x 3 = 67.05
DP50LF Epoxy Primer 55.55/quart x 3 = 166.65
DP402LF Primer Catalyst 31.95/pint x 2 = 63.90
DX330 wax/grease remover 42.30/gallon x 1 = 42.30
------------------top---------------------
PPG DCC Limestone $106.80/quart x 1 quart = 106.80
DCX61 Hardener 40.60/8oz x 1 = 40.60
DP50LF Epoxy Primer 57.75/quart x 1 = 57.75
DP402LF Primer Catalyst 55.50/quart x 1 = 55.50
MUDSUX
Old February 21st, 2013, 08:11 AM
Estimate your time as accurately as possible and then multiply by three. Virtually impossible on these trucks. It once took me an entire day to remove a salisbury. After hours of heat and dousing bolts with pb blaster I ended up cutting it out. Normally takes me under 2hrs.
Old February 21st, 2013, 10:20 AM
GYM's Avatar
GYM
Gary
97 SW
..and quadruple the amount of space you have estimated for the rebuild / interim parts collection and storage. Vehicles take up a lot more room when they are in pieces...
Old February 21st, 2013, 10:27 AM
Then there is the time spent ordering parts but not knowing that you actually need another part thats not listed to make everything work.....and the parts you order that don't fit. Thats happened to me already.
Old February 21st, 2013, 09:26 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If you know exactly what you have to build, year etc, you can go to a free microcat site and start to figure your prices. It also depends upon how much you want to replace and then what you are going to have to replace.
Land Rover 110
Old February 21st, 2013, 10:35 PM
Oannes's Avatar
Oannes
Aaron
[QUOTE=MUDSUX;415712]Barry had one for his 110 and I have seen a few others. My list is a mess, a work in progress, but here it is if you want to see. Last updated a few months ago and you could add a few thousand $ to this list for new retrim kits, Brownchurch HD Roofrack, etc. Close to $800-900 just for hardware like nuts and bolts. Plus 3 years of my life
/QUOTE]
Thanks Mud that is a big help and I have found some descent spreadsheets just to get a rough budget together, woking on a MS Project also for a build timeline...
I know that a bunch of you will say you cant time these things etc I just want to get and idea that I can show to my boss.
Aaron
Old February 21st, 2013, 11:04 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Are you insane? Don't show it to the boss! That is the dumbest idea ive heard in a long tome.
Keep a mental tally. You don't want anything down on paper.
-Jeff
Exactly!
Old February 22nd, 2013, 03:54 PM
Oannes's Avatar
Oannes
Aaron
Are you insane? Don't show it to the boss! That is the dumbest idea ive heard in a long time.
-Jeff
Not that boss the real one...
Aaron
Old February 27th, 2013, 10:59 AM
Oannes's Avatar
Oannes
Aaron
Been working on this sheet for those of you that are interested or OCD and need to know. I will share once it gets a little further along. I was able to find something that some else did for a Corvette rebuild that was a great start. let me know if there is any interest
Aaron
Old February 27th, 2013, 12:51 PM
UtahD90
Adam Harward
1995 Defender 90 SW
Would love to see it
factory LHD 1984 D90 build to SVX spec, Tdi rivermike For Sale - Vehicles 48 March 6th, 2013 07:12 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
NAS spec D90 tune resistor help required UKlandyandy Defender Technical Discussions 8 May 7th, 2005 07:05 AM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
