Broken transfer case drain plug - Defender Source
Old August 5th, 2012, 10:00 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Doing some work on the truck and decided I would swap the fluid in the t-case...put a wrench on the drain plug, turned and it was really easy but didn't really come out at all. I don't remember overtightening on the last install but the plug was definitely broken. I got a small flat blade screwdriver behind the head and kept working it until I got what appears to be around 1/2 of the plug out. I then grabbed the extractor kit and after having two different drill bits render themselves useless I am frustrated and somewhat stumped. I plan to hit the store for some "nicer" drill bits tomorrow but anyone have any ideas? Maybe try heating before drilling?
Old August 6th, 2012, 05:49 AM
Ray_G's Avatar
Ray_G
Ray Gerber
Jeff-
Had the same thing happen to me. To get mine out I had to drill a very tiny pilot hole and enlarge that enough to get the extractor to work-in doing so it also popped the magnet off the end of the bolt so it was loose in the TC. Just make sure you get that out; which will probably mean planning on pulling the inspection plate off.
r-
Ray
Old August 6th, 2012, 07:37 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
This one? http://www.defendersource.com/forum/...3&d=1343707481
Is whats left of the drain plug solid or hollow? I as i recall its hollow, if so snap ring pliers would work, if not, drill and easy out. Should be easy going as its brass.
-Jeff
What's left is solid and very hard, definitely not brass. I had some relatively sharp bits in my ez out kit that are now really dull!
------ Follow up post added August 6th, 2012 07:38 AM ------
Originally Posted by Ray_G View Post
Jeff-
r-
Ray
Thanks Ray. I plan to swing by and grab some drill bits this afternoon but will make sure I get some smaller bits too.
Old August 6th, 2012, 07:46 AM
Ray_G's Avatar
Ray_G
Ray Gerber
My experience was the same; I got on it with what I considered a small and sharp bit; and got nowhere b/c of the harnness of the plug. When I came back with one of the smallest in my selection it finally got a good hole started and that let me widen it slightly before going to the extraction bit.
All of which contributed to the magnet getting popped off though!
r-
Ray
Old August 6th, 2012, 12:41 PM
I think the last time I encountered this I punched the old plug into the t-case and removed the broken pieces with the bottom plate off. I just went to NAPA and got a bigger drain plug, and drilled and tapped the T-case to accept the bigger plug.
Old August 6th, 2012, 02:10 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
How much of the plug did you have left in the t-case? I would consider this a last resort but after messing with this for a while I did consider it!
Old August 8th, 2012, 09:34 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
After dulling/breaking a few more drill bits I decided to take out some aggression...took a punch and 5lb hammer, gave it a whack and voila, no more plug in the hole! The outer threads were still ok but the 12mm plug wasn't holding as well as I would hope so I tapped for 1/2" plug and seems to be all better now. I guess only time will tell!
Old August 8th, 2012, 11:11 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Jeff, we fixed a transfer case that suffered a similar fate by fitting a Time Sert threaded insert. Like a Helicoil, but better. I could send you the whole kit- drill bit, taps, counterbore, insert, and installation tool if you're interested in keeping an original drain plug set-up.
Just email the address and I'll send it out today.
Email is
Same place, new dogs.
Old August 8th, 2012, 01:37 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Awesome, thanks Trevor! email sent
Old August 8th, 2012, 06:41 PM
Are you sure you got all the bits out? Consider giving it a flush before putting too many miles on it (like say a trip to Rausch)
Originally Posted by pendy
I'm here for the D's
Old August 8th, 2012, 08:52 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I filled the bottom of the case (with the inspection cover off) and let it all drain out then reinstalled the inspection cover. I plan to fill the case with cheap oil, drive a cautious few miles and then drain and re-fill. if there are any particles in the drained oil I will probably consider pulling the inspection cover again
Old August 8th, 2012, 09:05 PM
If it is just aluminum particles I would not stress too much about it. Unless they are super huge. You did pull the bottom cover off, right?
Old August 8th, 2012, 09:16 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Yes, pulled the cover and removed the magnet along with several small pieces from the areas where I could get my fat fingers!
drain, drain plug, transfer case
Did I strip my Transfer case drain plug? J. Andrew Defender Technical Discussions 11 March 31st, 2011 12:32 PM
Transfer Case Drain Plug Problem kzack Defender Technical Discussions 10 October 21st, 2010 08:14 AM
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
