Broken rear door...how to fix?? - Defender Source
Old March 16th, 2014, 11:44 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
OK so I went to make a diamond plate door card for my rear door and found that it was cracked on the vertical supports and the door is pretty bent. As there is some special history to this truck I would like to keep the original rear door. Any suggestions as to best way to repair? I searched the forum but my search skills must be weak as I know this is a common problem due to the tire carrier.
Old March 16th, 2014, 11:51 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I have the same problem, but plan to replace mine.
I would suggest removing the door and having someone grind/weld up the broken parts.
Good luck!
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old March 16th, 2014, 01:47 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
At the very least a new frame and move the skin over if you want to keep the patina/history
We can have a new galvanized frame for you in the next container if needed.
Old March 16th, 2014, 02:38 PM
That looks more related to the bend than anything else - I'm guessing someone backed into something and hit the tire. Remove the skin, bend it straight, weld up and gusset it at key spots, paint and I think you'd be fine.
Originally Posted by pendy
I'm here for the D's
Old March 16th, 2014, 09:59 PM
El Solis's Avatar
El Solis
Chris Solis
The tire on the back isn't a bump stop?!?! kidding. Thanks everyone for the suggestions. I'm hoping to straighten and weld/repair etc and then mantec swing away tire carrier.
door, rear door
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
Rear anti rock redrover Misc. Chit-Chat 11 March 22nd, 2005 08:43 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
rear diff and rear seatbelts for '94 D90 rover_rich_d90 Wanted 1 April 20th, 2004 08:54 PM
