Broken ignition key ex mod 110 - Defender Source
Old April 25th, 2016, 10:15 PM
greenmountainrover's Avatar
greenmountainrover
Derek Chace
84 Lightweight FFR
HELP NEEDED! hey guys. I lent my mate my 89 ex mod V8 110 and some how he managed to brake the freaking ignition key in half.......no fucking idea how but he did.
What's the best option? I don't think any one can cut a key off the broken one....so I'm pretty fucked with an 110 with no spare key. Any help would be amazing.
Green Mountain Rovers your Defender/Series sales and importation specialist.
802-655-4874
Old April 25th, 2016, 10:34 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
As I recall, the tumbler pops out really easy. It's been a while so I don't remember the details but it comes out. After that, you can start the truck with an Allen key until you get a new tumbler, which is different from the newer tumblers. I don't have the part number handy.
Photo Apr 06, 6 21 58 PM by Chris, on Flickr
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old April 25th, 2016, 10:42 PM
A "good" locksmith can probably cut you a new key to fit what you have. It is only four codes, IIRC. Or pick it and get the barrel out which will allow a key to be cut.
You can get new barrels. They are cheap. If you want, you can get a whole set and replace them all...
Without a working key, you will need to carefully drill out the existing barrels.....
Old April 25th, 2016, 10:47 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
Question is finding the codes I guess.....Prefer not have to replace the whole ignition as that looks like a pain in the ass.
Ill call a locksmith in the morning
802-655-4874
Old April 25th, 2016, 10:52 PM
Ignition is super simple to replace on an MOD truck. 15 minutes. Really not much point to the key anyway. No steering lock and two seconds to hot wire.
Old April 25th, 2016, 10:53 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
So its not this horrible fucking thing im ready on with sheer bolts and drilling and all sorts of magical fun?
802-655-4874
Old April 25th, 2016, 11:13 PM
If you do not have a locking column it just pops right out. There is no security.
Old April 25th, 2016, 11:45 PM
Derek:
I can email you the ignition switch "bypass" instructions as well if you need them (after you take care of the column lock). It's been a common theme for folks as of late with the ignition switches delaminating (probably 1/2 dozen folks this month alone have reached out to me). This is assuming your ignition switch is similar to the NAS or ROW style on the ExMOD.
Old April 26th, 2016, 12:18 AM
MOD trucks do not have a column lock. It is just a simple switch.
Old April 26th, 2016, 12:32 AM
chris snell
Chris Snell
87 Ex-MOD 110
Did you read what I told you in the first reply?
2013 LR4
Old April 26th, 2016, 08:11 AM
I couldn't read anything you'd written due to being transfixed by the over-spray on your brake pedal ...
Old April 26th, 2016, 08:51 AM
Without the key, the tumbler will not come out without picking it or drilling the guts out of in. The normal procedure to remove the tumbler, is to insert the key then press the release pin in.
Old April 26th, 2016, 12:57 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
Scored a new ignition at RN for $15. Lucky I have the non locking petrol type
802-655-4874
Old April 26th, 2016, 01:17 PM
Hopefully they sold you the non-locking diesel type. The diesel version has the glow plug position, whereas the petrol one does not.
I will also suggest that for the long term to get an OE (Lucas branded) one (much more than $15). IME, the Chinese knockoff ones fall apart within a year or two.
Then pickup a barrel set and you can have all the keys the same.
Old April 26th, 2016, 01:21 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
The truck Derek is referring to is a V8 110.
Old April 26th, 2016, 01:26 PM
Good point....
Old April 26th, 2016, 03:19 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
All installed and sorted.
802-655-4874
WTB: key blanks for ignition and doors for 1988 110 Brentflyfish Wanted 5 May 6th, 2015 12:08 PM
key stuck in ignition D901619 Defender Technical Discussions 25 January 18th, 2008 02:55 PM
replacing ignition key - 94 snosrfr Defender Technical Discussions 10 June 1st, 2005 01:41 AM
Dumb ignition/door key question, did search first Neo Defender Technical Discussions 15 May 30th, 2005 07:10 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
