Broken halfshaft maybe? Can only drive in Diff Lock. - Defender Source
Old August 31st, 2015, 01:32 AM
Gish
David
1987 Defender 110 Ex Batus
So I was off roading on the weekend and broke something. Not 100% sure what, but it no longer drives unless in Diff lock lo/high.
I took off the tunnel and can see when out of diff lock the front shaft spins but no drive. Trying to do some reading on it and could it be the front halfshafts? I'm not 100% familer with the vehicle yet and wanted some advice
Cheers
Old August 31st, 2015, 08:36 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Have you already determined it's the front that's the problem and not the rear?
Old August 31st, 2015, 09:51 AM
David has an ex-MOD 110, so it is more likely a 10 spline shaft or diff than a CV. Most likely a shaft based on the lack of other symptoms.
In any case, you still need to pull the spindle to fix. Jack up each tire and spin. You can hopefully feel which side is broken and which is attached.
If you want a hand, let me know, I can pop around. I would suggest doing the work yourself. All Defender owners should know how to do this so that they can do it in the field. I also have some helpful tools like a shaft extractor that can save a bunch of work.
Old August 31st, 2015, 09:52 AM
slorocco
Dan Prasada-Rao
Yes.
-Jeff
that's cool, it wasn't apparent to me from the first post due to my own stupidity. Definitely follow Jeffs advice. I've been out on the trail with a badly blown CV. Had no choice but to limp back. I ended up with more collateral damage from driving on it.
Old August 31st, 2015, 11:22 AM
Do you have a pic of said tool?
-Jeff
I have the X-eng half shaft removal tool, the "X-shaft". Mine is the older version that stores one rod inside the other.
Old August 31st, 2015, 11:24 AM
Strangely just like the one on Lucky8's site: Lucky8 Llc. - Take the road less traveled... I wonder if they really sell the old version... Probably not. Just not great at website upkeep...
Old September 5th, 2015, 05:54 PM
Short shaft break at the root of the diff spline. The broken bit was too stuck for the magnet, so it ended up being a full diff pull.
fs
Replace Broken Bolts on LT230 Rear drive Flange-I must be missing something. 95beluga Defender Technical Discussions 4 March 8th, 2015 04:25 PM
Series Drive Train For trade (and maybe for sale later) WildBoar For Sale - Parts 0 September 10th, 2014 10:44 PM
t/c only works with diff lock engaged. tomaco1 Defender Technical Discussions 6 November 6th, 2011 10:03 AM
NY: LH front halfshaft assembly Lyman For Sale - Parts 9 March 25th, 2007 07:33 AM
94-95 headlight switch.. can be broken TDI Guy Wanted 4 May 17th, 2004 06:28 AM
