Broken exhaust manifold stud - Page 2 - Defender Source
Old December 11th, 2008, 12:03 AM
budz
sal gorriceta
various rovers
Smile
Originally Posted by pendy
You can get a small c-clamp from the hardware store. Pull off the t-handle and put a lock nut on it. Replace t-handle. Tighten and lock with second nut. It will last until your 4.6 or 200tdi install. Pesky inspector indeed.
Same thing what i did to my xd disco. It's been 3 years now and no problem also passes New York emission inspection every year.
Old December 11th, 2008, 10:12 AM
See why I love this guy? That's my kind of thinking! I thought about this (actually was thinking baby vicegrips just to get passed inspection), but dismissed it thinking the inspector might look up there or something and I really do need a more permanent solution than that. But you make it sound so much more viable with a baby c clamp.
Worth a shot I guess, but ordering gaskets and studs just in case and will pull the manifold Saturday if this doesn't work.
thanks again guys,
charles
Old December 12th, 2008, 04:07 PM
Well looks like I wasn't so lucky this time. This manifold has nowhere to clamp to.
http://lhsw.com/gallery/janey_exhaust_manifold
Also, there were no gaskets between the head and the manifold. I ordered some, and hopefully they will fit, but the parts manual doesn't list any. Seems very odd to me....
There was no gasket between the manifold and the downpipe, but the downpipe has a formed end and it looks like it should seal ok when bolted down properly.
Wish me luck getting these studs out (they all broke or got damaged)
Old December 12th, 2008, 04:55 PM
in the future try to take them off only when hot.
Ron
Old December 12th, 2008, 06:54 PM
Mmh, not sure it would have helped, but the reason I don't is to reduce the risk of burning myself. Maybe next time though.
Despite taking grandpa Bobeck's advice and heating the snot out of the studs before trying to turn them out, I broke all three. Oh well. All drilled and tapped now so no worries.
Old December 12th, 2008, 09:49 PM
cabell's Avatar
cabell
Cabell Crowther
There was a recent article in our local paper about "abuses" of antique registrations in Virginia. Many beaters (certainly Janey is not of this ilk) are apparently taking advantage and the troopers are discovering "unsafe" vehicles being operated under these regs. It sounds like the fuzz is watching antiques with a discerning eye, and the Commonwealth may at some point revisit the issue and possibly impose restrictions.
Old December 12th, 2008, 09:55 PM
Abrooks's Avatar
Abrooks
Tony Brooks
The Commenwealth has started requiring proof that antique vehicle registrants also have a non-antique vehicle as well -- without one they won't issue antique tags. The state has always been very antique friendly, but due to all of the abuses, they started cracking down. The need to prove possesion of a "normal" car was a comprimise that took a while to sort out but seems fairly rational. At the end of the day enforcement is looking for shitbox novas that shouldn't be on the road, not "funny looking cars."
Old December 13th, 2008, 12:30 AM
you tried to take them out?
well, glad to hear it is all back in working condition. so these are different than the disco/rr manifolds?
Old December 13th, 2008, 08:07 AM
Removed the old broken studs on the bench. I'm waiting for parts today to be able to put the new studs in and reinstall the manifold.
Old December 13th, 2008, 10:44 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I'll bet the ERR6733 later model gaskets would work just fine. They are joined and take care of 2 cylinders at a time. Plus, they are multipart so they seem to accomodate slight variations in head or manifold flatness well.
Email is
Same place, new dogs.
Old December 14th, 2008, 02:02 AM
Yup, I think that's what I got, and they fit fine. Still find it odd that it didn't have gaskets installed, but oh well.
exhaust
exhaust manifold temp? MUDSUX Defender Technical Discussions 4 November 19th, 2009 08:43 AM
300Tdi exhaust manifold problems crown14 Defender Technical Discussions 12 July 8th, 2009 11:38 AM
Whistle noise from exhaust manifold? markurski Defender Technical Discussions 11 November 27th, 2007 08:39 PM
Cracked Exhaust Manifold jamieh64 Defender Technical Discussions 9 November 22nd, 2005 01:04 PM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
