Broken Defrost Diverter Cable? - Defender Source
Old June 26th, 2008, 10:04 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Yes I searched for this one...
My defroster cable suddenly moves freely and the airflow is stuck in defrost mode. Is the cable connected a diverter under the dash or in the engine compartment? I assume I am going to have to pull the dash out?
Semper Fi!
Old June 26th, 2008, 10:25 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Check and pray that the issue is that it slipped or loosened up on the control lever side on the LH side of the dash. If it broke or slipped elsewhere then you get to take a good portion of your entire dash apart (its a sucky job).
Email:
Old June 26th, 2008, 10:28 AM
Wolf Fabrication
Sterling Archer
'08 D3
Man, I love Land Rover engineering!!! Thanks, I'll check the lever tonight.
Semper Fi!
Old June 26th, 2008, 12:21 PM
The diverter cable actuates some flapper valves in the lower half of the dash. If you reach up under the dash through the blow holes (it will feel a bit nasty) you'll be able to touch the flappers themselves - (the left and right sides are connected). The problem is that the diverter cable goes through the tray and actuates these flappers. The cable is anchored in the tray, but it is very weak, and pulls out easily. I think I have a picture, but I'm way too lazy to check now. Suffice to say, you can reach underneath the dash and assist the flappers while you move the lever on the cluster. It will work, but you'll feel a bit like you're molesting your truck, and you'll still have to fix it later.
Old June 26th, 2008, 04:15 PM
Wolf Fabrication
Sterling Archer
'08 D3
Thanks Jim! I'll sweet talk my truck when I do it. Maybe have some Barry White playing...
Semper Fi!
Detach Speedometer Cable Matt Klapmust Defender Technical Discussions 2 October 2nd, 2013 01:43 PM
broken throttle cable TravelerBT Misc. Chit-Chat 10 November 25th, 2008 10:30 PM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
Sub woofer cable? wicks Defender Technical Discussions 17 May 18th, 2004 09:51 PM
