Broken Bolt Headache - Defender Source
Old March 4th, 2016, 05:31 PM
FirstTithonus's Avatar
FirstTithonus
Dustin
1994 NAS 90 #313
A typical easy "easy project" turned into a headache today. Broke the end of this large bolt while trying to loosen it so I could install new side steps / running boards on the NAS 90.
Anyone know the size of this bolt so I can get a replacement or two in case the same thing happens on the other side?
The even bigger question: Will I be able to get this thing out in order to replace it without a lift and/or some creativity?
As always, your input is greatly appreciated.
Name:	D90 broken bolt (1).JPG
ID:	144247   Click image for larger version
ID:	144249   Click image for larger version
Old March 4th, 2016, 05:58 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I've had luck with penetrating oil, then get some good heat on it with a plumbers torch, then a BFH. An air hammer would be even better.
Semper Fi!
Old March 4th, 2016, 06:11 PM
The Dro
Dro
1988 Ninety
M12 x 180mm bolt
Old March 4th, 2016, 10:00 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Make sure to use a jack to lift the bulkhead to take the pressure off the bolt.
MUDSUX
Old March 4th, 2016, 10:16 PM
Those always break. I have never gotten one out in one piece.
Try to spin the other end after soaking and heating. Be prepared for extreme measures (chisel it out and drill the sleeve). Reinstall with a ton of anti seize.
Old March 4th, 2016, 11:15 PM
FirstTithonus
Dustin
1994 NAS 90 #313
Thanks for the info fellas. I'll post an update when I beat this thing. At dinner, my wife could tell I was pissed about something so I explained the situation about the broken bolt. We joked about the joys of owning a Defender and then she asked, "Are my hands small enough to be able to pull the bolt out?". Have to give her credit for caring. Hahaha.
ac
3 bolt or 4 bolt power steering box speedpin Defender Technical Discussions 4 February 17th, 2016 07:07 AM
Discovery 1 stereo wiring + amps headache hillstrubl Misc. Chit-Chat 5 May 31st, 2013 09:40 AM
3 bolt to 4 bolt LHD PAS box conversion kjva Defender Technical Discussions 3 April 3rd, 2012 06:20 PM
95 3.9l 10 bolt or 14 bolt head kolvedic Defender Technical Discussions 12 June 25th, 2010 11:40 PM
broken valve cover bolt...help!!!!!!!!! erik d Defender Technical Discussions 2 November 10th, 2003 03:12 PM
