Broken Axle Shaft, What to do with it - Defender Source
Old May 6th, 2008, 10:19 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I broke the rear axle shaft right at the flange. I replaced both with Rovertracks. Can I repair the broken one enough to use if needed to get off the trail if i were to ever break one again?
Old May 6th, 2008, 10:45 AM
Lyman
Lyman Saltsman
1987 Rokon Ranger
ah..... no. scrap steel is $300 a ton, throw it in the pile.
Old May 6th, 2008, 08:42 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Sit on it Potsy!
legend in my own mind
Old May 7th, 2008, 04:13 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Originally Posted by pendy
Sit on it Potsy!
AHHHHHH
Old May 8th, 2008, 12:39 AM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Plant it in the garden. The added Iron will do wonders for your vegges.
--Benjamin Franklin
Old May 8th, 2008, 08:30 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Make a knife or a good sword with it, it's hard steel ...
- Charles Eames
Old May 8th, 2008, 11:16 AM
If it is a long side you could rebroach it and use it as a short side, but I would sell you a used one for much less than the cost of broaching it. Also, I can pretty much gaurantee you will not break a rovertracks axle with the truck in your avitar.
Old May 8th, 2008, 12:52 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Wait a minute. Are baggin on my truck?
axle
end of axle shaft hole thread size cgalpin Defender Technical Discussions 9 August 5th, 2009 10:45 PM
How Many of You have Broken an Axle? mdmccallum Defender Technical Discussions 11 April 23rd, 2008 06:13 PM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
24 Spline Axle Shaft (Long Side) + CV Joint + Rear Housing mudrover For Sale - Parts 0 March 2nd, 2005 09:48 AM
