Broke something not sure what or how bad - Defender Source
Old May 3rd, 2006, 01:55 PM
WestTexasDefender's Avatar
WestTexasDefender
Sam Allen
'97 LE #234
I'll start off with how it happened. I was trying to cross a narrow creek bed and sunk down to the doors on the left side and was on dry ground on the right. Everthing was really bound up and had it in low lock(stock not lockers). I had the brake down trying BTM and at around 1500-2000 rpms all the tension and everything gave way and there whas a loud pop and grinding when it was in gear. I got it out of the creek and couldn't find what broke but it will only drive in either high lock or low lock but it pops and grinds. Took out the front drive shaft and that didn't do much. I'm lost at what it might be and am going out to my land to work on it tonight. Any advice as to what the possibilities to what it might be would help a whole lot.
Old May 3rd, 2006, 02:37 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Sounds like you blew a diff, thats why it only moves in diff lock.
Old May 3rd, 2006, 02:39 PM
I would check front axels and CV's. More than likely, it should be the short side CV. I have done this sevearal times. Over time and use, the inner cage of the CV gets stress cracks, then when you put an extra load on them, they break.
Old May 3rd, 2006, 02:50 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
my guess is the CV too,not the diff !
Old May 3rd, 2006, 04:02 PM
WestTexasDefender
Sam Allen
'97 LE #234
Ok I was suspecting the CV from reading what usually breaks on the defender. Is there a stronger better part the I could replace it with?
Old May 3rd, 2006, 04:22 PM
New CV's
There are a few options...
1 GBR's Axels and CV's, great stuff... $1700.00
2 CV unlimted in SC. $899.00 - you can call George Stuckey (4340 Chromo, heat treated and Cryo'd.)
I have CV unlimited in the front and GBR's in the back. Both are excellent.
Old May 3rd, 2006, 10:12 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Check with http://www.rovertracks.com/
Very good stuff, great guy to deal with.
I did the whole front end inner/outers in my RR.
Old May 4th, 2006, 02:00 PM
WestTexasDefender
Sam Allen
'97 LE #234
Ok took it apart last night and this is what it appears I need:
1 Left Front CV Joint assy
1 Left Front Inner Axle Shaft
1 Outer Spindle Grease Seal
1 Outer Axle Tube/Shaft Grease Seal
1 Knuckle/Axle Ball Grease Seal
If I choose to upgrade to the heavy duty stuff will I need to buy it for the right wheel also?
Old May 4th, 2006, 02:04 PM
Yep... I would not make sense to upgrade just one side.
Your other option is to find a LR Salvage yard and get the parts off a disco.
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
Front Air Vent Lever Broke...Argh! boshea Defender Technical Discussions 5 February 15th, 2006 08:08 PM
Help!!! broke zerk and bent panhard rod Milo Defender Technical Discussions 3 June 14th, 2004 01:43 PM
Broke the 500 mark chrisvonc Misc. Chit-Chat 15 April 11th, 2004 04:07 PM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
