Broke Down - Defender Source
Old December 14th, 2013, 12:12 AM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Broke Down
I just broke down on 71 north near Columbus en route to warren Ohio. Lost my wipers ten later my lights -pulled onto the shoulder and the my 110 died. Alternator? Is there anyone around that I can take my defender to once the tow truck arrives?
Old December 14th, 2013, 12:16 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
birmabrightbrotherhood.com
Anthony Cordo
Address
43215 - Columbus
Contact Number
740-398-9331
Land Rovers
Series
Access to a tow truck or trailer?: No
Access to repair facilities?: No
Spare parts available?: Yes
Can you provide overnight accommodations? : No
Mike Watson
Address
45368 - South Charleston
Contact Number
614-578-4775
Spare parts available?: No
Can you provide overnight accommodations? : Yes
Old December 14th, 2013, 12:21 AM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Thanks Bill ill call them up in the morning.
Old December 14th, 2013, 12:32 AM
Bill Larson
Bill Larson
Good Luck...Stay warm!
Old December 14th, 2013, 12:33 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Sounds like alternator. A voltage check will reveal if the motor was running off the battery.
A battery swap could at least limp you to a better location to work on the truck.
Semper Fi!
Old December 14th, 2013, 01:53 AM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
The live feed came off the alternator because the nut fell off. Does anyone know what size it'd be? I'm in a hotel for the night and will go to a parts store in the am. Thanks all.
Old December 14th, 2013, 02:11 AM
Not sure, but you could find one on the truck to fit I am sure.
Old December 14th, 2013, 02:14 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Rob a nut from a non critical location on the truck.
Old December 14th, 2013, 09:01 AM
87 D110 (Ruby)
Or go to sleep and wake up and do it.... - unlike some folks on here!!! SLEEP
Everything is always better the next day.
Old December 14th, 2013, 09:35 AM
Bill Larson
Bill Larson
X3...
Old December 14th, 2013, 09:49 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
6mm X 1.0 or 1,25 depending on the unit.
Dennis had good advice... pull a nut of some BS fitting, tighten with a 10mm whench or socket, get a jump, an GO!
RDavisinVA
Old December 14th, 2013, 09:35 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Exactly what I did haha. 2 am on the side of a highway in snow with no lights is not a safe place to search your engine compartment for hardware. Swapped the nut and got home fine...relatively fine but made it from western Ohio to Maryland with no heat or indicators but ran pretty well! Thanks all
Old December 14th, 2013, 10:37 PM
When this happened to me it was because the stud on the alternator had corroded so much that you couldn't thread a nut onto it. Of course this happened when I was driving through the mountains at night in 10* weather. I ended up using some JB weld on a new nut to hold it in place. It held up until the alternator eventually failed, then I put in a Disco alternator.
Old December 14th, 2013, 11:44 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Of course, why would it happen in a garage or a comfortable environment with tools and parts? Is the disco alternator a fairly simple swap? Since mines original I'm thinking of replacing it.
Old December 15th, 2013, 10:24 AM
I was told that it would bolt up if I cut one of the ears off, but it also involved a lot of grinding on the alternator bracket. I wouldn't suggest going this route. I only did because I had already bought the alternator and needed to use my Defender.
Front Air Vent Lever Broke...Argh! boshea Defender Technical Discussions 5 February 15th, 2006 08:08 PM
Broke Down Help Campbell Defender Technical Discussions 3 August 30th, 2004 05:29 PM
Help!!! broke zerk and bent panhard rod Milo Defender Technical Discussions 3 June 14th, 2004 01:43 PM
Broke the 500 mark chrisvonc Misc. Chit-Chat 15 April 11th, 2004 04:07 PM
My viscous coupling be broke! dboehme Defender Technical Discussions 6 October 6th, 2003 11:32 AM
