Britparts for 300Tdi ancillaries build-up? - Defender Source
Old July 18th, 2016, 07:36 PM
KY-Defender
Raymond Orthober
1987 D-110
Question – Is Britpart an OK source for some 300tdi ancillary bits and bobs, bolts, nuts, brackets, washers, gaskets and seals, rubber hoses and other non-moving parts?
IE: Are they an acceptable supplier for the engine parts that hold the engine together (rather than the parts that keep the engine moving) ?
Their parts, at first look, seem the economical choice, but I always see lots of **** substituted for letters in their name….
Regardless of the part source, is there one vendor in the UK that is regarded as a superior supplier?
I am looking at Paddocks, John Craddock, LRDirect, Bearmach from which to order…
Backstory.
I will be doing a 300tdi build up from a Turner stripped engine (mated to R380) and am gathering the ancillaries.
I don’t have an old/spare 300tdi to cannibalize, so I’m deciding to purchase these parts in batches from a UK supplier hoping, in the end, this will be a less expensive option favoring the reliability of a new part over the unknown of a used.
Additionally – regarding engine ancillaries…
Are there any Britpart items that are universally regarded as reliable or foolproof and worthy of purchase?
Which general Britpart items are known to have QA issues (IE the moving parts)?
Which 300tdi ancillary items would you only consider using genuine LR (if any)?
Thanks in advance for the discussion.
Raymond
Old July 18th, 2016, 07:48 PM
Naplm00
Matthew
I am not the norm here but, I use everything they make except for seals and complex parts like wheel cylinders and clutch items.
Gaskets, bolts, brackets, hoses, ect seem hard to fuck up.
I have used a britpart Ps pump but gave it a once over and used original crush washers on the feed line when installing. Been ok for years
Old July 18th, 2016, 08:01 PM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
Britpart is just a distributor. You can get good parts and not-so-good parts from them. They do supply a lot of OEM parts and a lot of stuff from reputable manufacturers. If I buy things distributed by Britpart I make sure it either says OEM on the label or that the product is obviously made by a good company, e.g. VDO, Lemförder, etc.
300tdi, part, parts, tdi
2_1992 Discovery 200tdi engines w/ancillaries southernoverlandco For Sale - Parts 13 August 6th, 2016 01:49 PM
Defender 200 Tdi engine with ancillaries rtcgb For Sale - Parts 16 May 16th, 2014 04:24 PM
'87 110 CSW 300TDi Build duhmingus Truck Build-up's & Restores 40 October 6th, 2013 08:04 AM
For sale or trade: 2.5 NA, LT77, 1.6 and all ancillaries ontheway For Sale - Parts 3 March 23rd, 2013 09:13 AM
help with 3.9 ancillaries vesparover Defender Technical Discussions 4 July 19th, 2005 10:49 PM
