Britpart 200TDI timing belt tensioner - Defender Source
Join the Defender Source Community Today
Old July 8th, 2016, 02:23 PM
AdamSanta85's Avatar
AdamSanta85
1991 D90 SW
I bought a timing belt kit from RovahFarm for my 200TDI. It came with a Britpart tensioner. At the time I was not aware of their (terrible) reputation. Would you guys buy another tensioner ($30ish), or just use it? The fact that it isn't a hydraulic tensioner or anything tells me to just go with it, but maybe that brand really is THAT bad?
Old July 8th, 2016, 02:25 PM
This belongs in the Britpart sub-forum
Old July 8th, 2016, 02:29 PM
AdamSanta85
1991 D90 SW
You're a sassy one. I do agree it should be in the diesel engine sub-forum though
Old July 8th, 2016, 02:37 PM
Get an OEM one. Make sure that is not what you have first. Britpart sell both an OE version and a mystery sourced version.
Old July 8th, 2016, 02:40 PM
AdamSanta85
1991 D90 SW
Ill post a pic later when I get home. I don't know how to tell the difference, and I don't want to find out the hard way when my truck is on the lift.
Old July 8th, 2016, 02:41 PM
Ask Rovahfarm.
Old July 8th, 2016, 06:02 PM
Naplm00
Matthew
Wrong info, mixed up with another type
Old July 8th, 2016, 06:39 PM
AdamSanta85
1991 D90 SW
Originally Posted by Naplm00 View Post
The cheapie one has a open center section from the front. The oem style is solid in the front
I can't tell. I worked in auto parts for years, never saw stuff that didn't have part numbers on the box. Talked to Trevor @ RovahFarm he said there is only one tensioner? He sounded unsure but said he has sold many kits and never had a complaint FWIW.
Old July 8th, 2016, 06:51 PM
Britpart sells two. I'm looking at their parts list. The oem one will have G at the end of the part number.
Old July 8th, 2016, 06:54 PM
AdamSanta85
1991 D90 SW
I saw that. No part numbers on the box, or the part. Not even evidence of a prior labeling sticker. How do they even know its their part in the event of a failure?
I don't have a problem buying another, but I don't want to end up with the same thing. (If this is a shitty one)
?? They need an open center as that is where the securing bolt goes.
ERR2530G is the BP part number for the OEM one.
Old July 8th, 2016, 06:56 PM
Pretty sure the front should have INA markings.
Old July 8th, 2016, 07:23 PM
Naplm00
Matthew
My fault wrong info
Old July 8th, 2016, 09:44 PM
AdamSanta85
1991 D90 SW
Thanks guys I ordered the INA. It wasn't worth chancing over a $45 shipped part.
Old July 15th, 2016, 11:21 AM
AdamSanta85
1991 D90 SW
Figured I would follow up. I ended up ordering the INA OEM tensioner. Can't really tell a measurable difference in quality between the two (which is what I expected). However I feel better knowing the bearing is most likely of better quality.
Here is a comparison between the two
200tdi, part, tdi
300TDI Timing Belt Tensioner Viton For Sale - Parts 1 September 2nd, 2011 09:31 AM
300tdi timing belt tensioner Viton Defender Technical Discussions 4 August 14th, 2011 09:03 AM
Freelander Timing belt Tensioner mjekogian For Sale - Parts 0 August 11th, 2010 11:44 AM
Head Gasket, Timing Belt, Drive Belt - What else? GreenRover Defender Technical Discussions 5 July 16th, 2010 11:23 AM
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 14th, 2009 11:20 PM
