Brass Radiator Plug - Defender Source
Old May 8th, 2006, 01:10 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
Brass Radiator Plug
Well, i fell victim to advertising and bought one of the brass radiator plugs thinking my plastic plug was going to melt any day now. So i put it in ran the truck for a little while and watched as the fluid raced out of the radiator. The O-ring that is supplied doesnt seem to fit ontop of the radiator, it just expands and folds over the edge. So i took the o-ring off and tried it again, same things, i put some tape on the threads, no luck....
Has anyone got one of these fancy plugs, and does yours leak?
Thanks for the help
Kris
Old May 8th, 2006, 01:28 PM
Matt Taylor
Matt Taylor
I've got one that works fine.
Old May 8th, 2006, 01:45 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Thanks for the help
Kris,
I have the same problem. Got the brass plug from BP and it leaks. I've tried teflon tape and same problem.
Maybe we got a bad batch of plugs.
John C.
Old May 8th, 2006, 02:00 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Sounds like there are 2 plugs out there.
I have the Maxi-drive version they sell @ EE. Works fine and I have never had one issue with it.
Sounds like the BP one has issues?
EwS
Old May 8th, 2006, 02:14 PM
BeachBum
Paul Schuetz
1991 Range Rover
I had that plug blow out while waiting in line to cross the border from Mex. back into Ca. Had to push the truck at walking speed in traffic for 3 hours, no where to go or get out of the way. Had 4 mexicans come over to help and pushed all the way until we were about 50 feet from the crossing. They were scared to get any closer. Then the border guards helped push it through where another nice group of mexicans asked if I had a tow strap and dragged me down the road to Pep Boys in Calaixico. The top of the stupid plastic plug blew off leaving the threads in the hole. Unscrewed that with a flat head screw driver and took that peice inside, found a differential plug that came in a 2 pack for $4. They didn't have another replacement. Wrapped it in teflon tape, screwed it in, filled with coolant and it's been there ever since. I keep the extra one for whomever loses thiers next.
Later, Paul
Old May 8th, 2006, 02:59 PM
Billakris's Avatar
Billakris
Kris
I dont know who made mine, but I ordered it from DAP. At least I know im not going crazy.
Anyone know of a fix for this? I even bought a smaller o-ring, but it is still too large for the lip of the radiator.
Kris
Old May 8th, 2006, 03:42 PM
mattdh's Avatar
mattdh
Matt Hurst
i purchased the plugs from dap and my o-ring did the samething. i screwed the pulg down and tucked the oring back under the plug as i turned. got it as far as it would go with out mashing the oring out.has not leaked yet-knock on wood
Old May 8th, 2006, 03:51 PM
Billakris's Avatar
Billakris
Kris
I tried that method too, maybe i just dont have enough finese. Ill try that again and see how it works. Thanks for the help
Kris
Old May 8th, 2006, 04:00 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Huh. I have the EE ones and they are great. I broke a plastic one already. THey suck..
Legend in My Own Mind.
Old May 8th, 2006, 05:15 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
I got one at Napa, try a brass washer instead of the O ring.
Old May 8th, 2006, 05:41 PM
SYoung
Steve
94 D-90 #8
The trick is to cinch it down tight, but not so tight the o-ring squeezes out. I have 'em on my DI and D-90 without a problem.
Old May 8th, 2006, 08:17 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
EE. works fine
Old May 8th, 2006, 10:52 PM
Billakris's Avatar
Billakris
Kris
Thanks for the replies!! Ill give it a shot
Kris
Old May 10th, 2006, 01:47 AM
EE worked on mine!
Old May 10th, 2006, 09:20 AM
mattdh's Avatar
mattdh
Matt Hurst
i guess that why ee is is $20 and dap is $15
Old May 10th, 2006, 09:55 AM
JohnC
I guess I'll have to order a few from the UK, looks like they cost under $10 in the uk.
John C.
Old May 10th, 2006, 08:03 PM
beacause you have to pay for thier expensive habits (EE)
Old May 10th, 2006, 08:17 PM
artm
Arthur Maravelis
97 SW
Perhaps it's time for a UK group buy. I'm in for two. Anyone check with George first?
Old May 11th, 2006, 11:35 AM
Why not group buy from Maxi-Drive. Last I check he charges $7, but that may have gone up.
radiator
Brass Radiator Plugs Abrooks For Sale - Parts 29 March 19th, 2017 11:23 PM
Ammo and brass FS stu454 The Flea Market 2 December 7th, 2009 03:09 PM
Brass radiator plug ERR4686 JFD Defender Technical Discussions 9 November 30th, 2009 09:10 PM
D90 rotors, pads artm Defender Technical Discussions 12 April 12th, 2007 01:19 PM
Front GBR Extreme Duty 23/24 inner axles, D110 CV's and spindles w/ brass bushing lwg For Sale - Parts 8 February 9th, 2005 01:08 AM
