Brakes - no pressure after rotor/pad replacement - Defender Source
Old March 13th, 2011, 12:33 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
I replaced my REAR rotors & pads yesterday (did the front brakes last fall). Bled them all from rear to front, topped off the fluid. But now I don't have any brake pressure. When I press the brakes, the pedal goes to the floor with minimal resistance. After a few pumps, it seems to build pressure briefly, before losing it again. I've checked all of my brake pipe/hose connections, no leaks. Any ideas on what I am missing (or what I screwed up)?
Old March 13th, 2011, 01:46 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
You still have air somewhere in the system.
Old March 13th, 2011, 03:37 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
Yep - took another cup of coffee to find the connection that wasn't seated properly. Thanks -
Old March 13th, 2011, 03:47 PM
kevkon's Avatar
kevkon
kevin
Can never have enough coffee!
Old March 13th, 2011, 04:56 PM
NoVaKevin
Kevin
sold#1469
paging horsey for advice....man down....in need of rotor replacement assistance....
Old March 13th, 2011, 05:15 PM
Rotors wouldn't cause that, but air in the system would.
Old March 13th, 2011, 07:38 PM
specops1526's Avatar
specops1526
Beluga '97 90
Horsey's only advice would be to forget the Rotors and just add new pads.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old March 13th, 2011, 07:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
New pads and old rotors make for perfect adjustment. No need to bleed.
Old March 14th, 2011, 06:53 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
On that note, I have some 'slightly' used rotors available for you Josh.
Btw, I see a NAS 90 parked on the street every now and again when I'm in hoboken. once near the train station, and another time in front of the post office. Has a roof cage if I remember correctly. Didn't see any rhino-lining tho. You know the one?
Old March 14th, 2011, 07:08 PM
I see them a bunch here. Color usually helps narrow it down though.
I can't remember if one of the yellow ones had a cage. Pretty rare w/ the cage around here because of garage clearance.
Can't believe you've been here and not hit me up.
Old March 14th, 2011, 08:39 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
I know, it took every ounce of willpower not to come see your collection of soft tops. Next time may be a different story.
ac, brake
Confused about oil pressure sender. VDO replacement sundogcwolfe Defender Technical Discussions 3 May 20th, 2010 06:24 PM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
