brakes, need help with part # - Defender Source
Old February 15th, 2013, 10:29 AM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
I replacing the front brakes on d90, can anybody tell me what part # it would be? Numbers stamped on caliper is Lockheed LB10TY016AC for the right side and 017AC on the left side. It's a 1986, but the running gear has been updated and I'm not sure what year the gear is. I'm talking to safari now and they said they would call back.
Old February 15th, 2013, 10:35 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
They look like RRC/D1 non-ABS brakes to me.
What part number do you need, the pads?
Old February 15th, 2013, 10:38 AM
CavemanDiesel
Eric Smirh
1985 D90
I replacing rotors, calipers and pads.
Old February 15th, 2013, 10:55 AM
Just get the new pistons and seals from (insert favorite parts vendor name here) and you'll be golden. Rebuilding the calipers is fun and easy. Soak them in Rust Solve overnight and they will be all ready for a couple coats of day-glo green or pink.
Old February 15th, 2013, 11:00 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Dual Piston, non vented.
1. http://www.paddockspares.com/seb5004....html?___SID=U Caliper
2. Pison seal kit http://www.paddockspares.com/aeu1547....html?___SID=U
3. Maybe the piston http://www.paddockspares.com/606683-....html?___SID=U
I think there is a conversion write up on LR4x4.com
------ Follow up post added February 15th, 2013 11:03 AM ------
If you want to upgrade, I think the answer is in the last post here.
http://forums.lr4x4.com/index.php?showtopic=47234
Old February 15th, 2013, 11:03 AM
You can get a Zeus kit that has the spacers for the vented brake calipers, or you can get them out of a set of RRC/Disco calipers. Keep the inner seals as I haven't seen them anywhere, and use the RRC bolts that hold the caliper halves together. Then you can run vented rotors.
Old February 15th, 2013, 11:24 AM
tjfslaughter
thomas
Burbon
Interesting video:
Old February 15th, 2013, 12:06 PM
Save yourself nine minutes and scrub forward to 9:10. Everything else you can ignore.
I did not find it necessary to heat or freeze the parts.
Old February 15th, 2013, 12:39 PM
tjfslaughter
thomas
Burbon
Is it as easy a it seems? I am going to order the Zeus stainless kit.
Old February 15th, 2013, 01:39 PM
It is easy if you have a big C-clamp and a trailing arm bush washer.
Old February 15th, 2013, 01:44 PM
tjfslaughter
thomas
Burbon
Got the clamp. I am fairly sure I can get a big washer. When I do my pads next time I will give this a try.
Old February 25th, 2013, 01:53 PM
CavemanDiesel
Eric Smirh
1985 D90
Thanks for the input. I went with new rotors, calipers and pads, look at the bling... I'm gona paint the calipers hot pink and drive to NY.
Does anybody have a need for the old calipers? Free to a good home if you can rebuild. The left one was working the right one was leaking. Let me know, you pay shipping.
Old February 25th, 2013, 03:22 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
I could hook you up with a set of boost wheels.....
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old February 25th, 2013, 03:31 PM
CavemanDiesel
Eric Smirh
1985 D90
Lol, already got the boost. They won't let you NJ without them.
Old February 25th, 2013, 03:48 PM
Looks good. For the next person, if you are replacing everything, you can upgrade to NAS D90 vented discs and calipers since you are replacing everything.
Old February 25th, 2013, 03:52 PM
CavemanDiesel
Eric Smirh
1985 D90
Dam, did not know that, well, live and learn. With the high speeds, I'll wear these out in no time. Lol, this is all a learning curve for me. Do the NAS bolt on with no mods?
Old February 25th, 2013, 04:55 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Attachment 66920
Can you do me a favor and measure the outside diameter of the pistons and let me know if you come up with 41 or 46mm. Thanks.
Old February 25th, 2013, 04:57 PM
I'll take them Eric! I want to switch my project RRC brakes to single line. I'll send you a PM.
charles
Originally Posted by pendy
I'm here for the D's
Old February 25th, 2013, 05:27 PM
Yes. No mods other than two new bolts. There is very little difference in braking power in my experience, but vented rotors are actually cheaper than solid ones.
Old February 26th, 2013, 07:51 PM
CavemanDiesel
Eric Smirh
1985 D90
Sorry for the delay, so who gets first dibs? Fish or Charles, I'm new to this used parts deal.
brake, part
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
Part number for genuine roof rack? wicks Defender Technical Discussions 13 March 3rd, 2004 06:34 PM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
