Brakes master and booster question! - Defender Source
Old April 11th, 2013, 07:51 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
So I got a late model booster from somebody on the board a while ago. My issue is that it's a later model (2004) I think, and the only brake master that will fit is from a DII. Problem is that the reservoir is at a bad angle, and the hook ups are all on the inboard side, all the trucks I've found pictures of 94,95-97 all seem to be on the outboard side. Compounding the problem is that I was going to get stainless brake lines and they're only available for 94,95 and 97s.
I was also wondering if all three years of 90s came with the brake thingy in picture 3?
ID:	69962   Click image for larger version
Old April 11th, 2013, 08:29 PM
I don't think you want the new stuff. I think it is supposed to work with ABS.
Just recreate the original 1983 system or recreate a NAS 90 or 110. You must have the original tower floating around.
Old April 13th, 2013, 06:49 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Does anyone know if 94, 95, and 97s all use this valve for the brakes?
Old April 13th, 2013, 11:39 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Tom,
That looks like the one on my 1984
Would be intrested in seeing what you come up with, I am stuck at the same place on my build as well.
Old April 14th, 2013, 06:58 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Anyone know if its on a 94, 95, or 97?
Old April 14th, 2013, 09:56 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Tom,
I looked through a few build threads and found the following pics
Chris V 1995
http://www.defendersource.com/forum/...5&d=1276133220
Safari HP Norad rebuild from NAS 90 to 110 (lines look the same as Chris V build)
http://www.defendersource.com/forum/...6&d=1313609189
1997 NAS build crown14
http://www.defendersource.com/forum/...6&d=1253583350
Looks like the NAS 90 stuff has a diffrent valve to me
Old April 14th, 2013, 11:03 AM
Nas 110
Old April 14th, 2013, 08:05 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Very helpful,
thanks.
It looks like the 90s are different, they don't show a 94 though.
Old April 14th, 2013, 08:38 PM
94 is the same as 95. The 110s with rear drums have the set up you and the NAS 110 have although I don't know of people switching them out when they convert to discs.
Ron
Old April 15th, 2013, 07:38 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I left it on my 110 when I changed to discs, seem to work just fine.
On the 90, I have what looks like the junction in Dave's pictures(95 and97) laying around from a 1997 disco
Old April 15th, 2013, 08:08 PM
Not sure if disco is the same or not.
boost, brake, master
Rex range rover classic vacuum brake booster pedal box assy the rover shop For Sale - Parts 4 May 6th, 2013 09:16 PM
Poor Brakes - Master Cylinder ? kzack Defender Technical Discussions 1 August 6th, 2012 12:36 AM
brake booster? tomaco1 Defender Technical Discussions 3 October 2nd, 2009 04:15 PM
Dual diaphragm booster from RRC? ajh Defender Technical Discussions 3 March 4th, 2009 01:30 AM
cracked brake booster: interchange? jaherring Defender Technical Discussions 4 November 29th, 2007 08:33 PM
