Brakes - Defender Source
Old November 4th, 2009, 05:17 PM
bjf's Avatar
bjf
barry f
94 ST #395
Brakes
I am pretty sure I need new pads in my 90. Front and rear. I will do it myself as I am now a master mechanic. My question is, how do I know if I need to resurface my rotors? I have 60,000 miles on the truck and this is it's first brake job that I can tell.
Yeah I said I am a master mechanic.
Old November 5th, 2009, 01:49 PM
bjf's Avatar
bjf
barry f
94 ST #395
bump
Old November 5th, 2009, 01:55 PM
Are the rotors heavily scored? Are then under spec for thickness? If the answer to both questions is no, then they are fine and you can reuse them. If the answer to either question is yes, you should replace the rotors and not turn them. If you really have 60k on rotors, I would replace them. tntlr.com has some cheap ones on his website.
Old November 5th, 2009, 02:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah I assume they are original. I am not sure if they are scored though. I have to get into it and look.
Old November 5th, 2009, 02:13 PM
If it is the D90 you can look though the spokes of the alloys, on the 110, just look at the back side of the rotor from under the truck.
Old November 5th, 2009, 02:14 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
I've always heard that rover rotors shouldn't be turned b/c they won't be within spec afterwards (too thin to start with I guess)...
I kind of enjoyed doing the brakes on mine last spring. The hardest part was removing the hub from the rotor. That was a bitch.
Old November 5th, 2009, 02:15 PM
Slather with anti-sieze when you refit it, comes off easy the next time.
Old November 5th, 2009, 02:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have 110 wheels on my 90 so I can't look through the spokes. If I do need rotors do I go stock or those australian ones?
Old November 5th, 2009, 02:52 PM
Genuine are my preference but brembo brand stock are not bad either and I hear delphi are decent too. No experience with DBA rotors.
Old November 5th, 2009, 02:53 PM
cdb
Clark Bowen
I have the drilled and slotted rotors and couldn't feel any difference.
2011 RR HSE -
2001 GMC 2500 4wd
brake
D-90 Brakes scot Defender Technical Discussions 20 April 23rd, 2009 12:17 PM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
Wheelies and brakes! TwisteD90 Defender Technical Discussions 7 January 10th, 2006 10:31 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Brakes: Slotted & Drilled or Not mhansen Defender Technical Discussions 2 March 29th, 2004 03:06 PM
