Brakes - Defender Source
Old March 30th, 2009, 06:48 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Brakes
My 94 D90 needs the rear disc pads changed, anything to lookout for? will I need a hardware kit?
Also I'm loosing brake fluid which by the way is DOT 5 & expensive, it seems to be driping thru the resovior area I think,...I will clean it all with brake cleaner & see just were its dripping from...should I just replace the seals for the resovior if it turns out to be the culprit or the complete unit?
Old March 30th, 2009, 08:37 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
No special hardware needed for changing the pads.
Jimmy Buffett
Old March 30th, 2009, 09:18 AM
Complete unit on the MC.
Old March 30th, 2009, 10:02 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Ron,
is it a big job?
yes or no
Old March 30th, 2009, 10:18 AM
Not really. Bleeding is the only time consuming part assuming you don't break any of the lines while removing them from the MC.
Old March 30th, 2009, 10:43 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Just changing the pads is really straightforward and painless. You won't need anything other than a few normal hand tools. If you are going to remove the rotor to replace it or have it turned, then things get a little more interesting. But still not too bad.
Old March 30th, 2009, 10:58 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
sounds pretty straight forward then...for the pads.
thanks
To be clear, I was talking about the master cylinder replacement, but MIke is spot on concerning the pads and rotors.
Old March 30th, 2009, 11:14 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
thanks Ron...
Old March 30th, 2009, 02:17 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
It will take you longer to jack up the vehicle and take the tires off than it will take to replace the pads.
Old March 30th, 2009, 02:46 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I was losing fluid around the reservoir too. I bought a rebuilt kit from AB (http://www.roverparts.com/Parts/SJJ100351G.cfm) and it is a straight forward job. rip the reservoir up and out. then undo the 2 brake lines that are in your way. and then the two nuts. take it all out and replace the rubber seals and yellow plastic piece.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old March 30th, 2009, 04:33 PM
Joeplumbo's Avatar
Joeplumbo
Joe PLumbo
1993 110
Is DOT type 5 synthetic? The seals in a '94 may not be able to handle that fluid. I imagine though that the upgrade would be made from more modern and resilient materials and it may not be an issue.
Joe
Old March 30th, 2009, 04:42 PM
Use castrol GTLMA. BTW a whole new MC is only $100 more than that kit and given that yours is nearly 15 years old, I would buy a whole new one.
Old March 30th, 2009, 07:05 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Well just above the master cylinder someone put in big stick on letters DOT5 Only, so thats what I put in, but Ron has a point about replacing the whole unit at once.
I have done many brake pad changes in my day,..so sounds like a straight forward install.
Old March 30th, 2009, 08:51 PM
I would bleed all of that DOT 5 out of it (before you swap the master) and switch to castrol GTLMA.
And here is the biggest tip on replacing the MC. BENCH BLEED IT FIRST.
Old March 31st, 2009, 07:18 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
yes, I was planning on switching to stainless brake lines & bleed system to GTLMA then swap out Master Cylinder.
The old girl should be happy then.
Long term would be to get vented disc & new calipers.
brake
D-90 Brakes scot Defender Technical Discussions 20 April 23rd, 2009 12:17 PM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
Wheelies and brakes! TwisteD90 Defender Technical Discussions 7 January 10th, 2006 10:31 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Brakes: Slotted & Drilled or Not mhansen Defender Technical Discussions 2 March 29th, 2004 03:06 PM
