I had that fr^T&(ing trailer light connection plug corrode, short out, melt wires and do everything from light the dash up to having the reverse light come on when you use the radio !
The culprit has been up inside the frame rail where the trailer plug is connected and will resemble a small snake that has eaten a large rodent (that is wearing a green sweater)
We've seen this a few times recently that were traced down to a bad batch of 12v 1157 bulbs. They short internally so that when you hit the brakes it back feeds power back into the parking light circuit (dash lights).
Pull the bulb and then test the system to check if that is the issue.
way to go Mike.....another "been there , done that"?
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
