Brake Upgrades - Defender Source
Old April 29th, 2015, 07:28 AM
Celtic Nomad
Geraint Jones
2013 110 Double Cab
Brake Upgrades
Hi All,
I am looking to upgrade the standard brakes on my 110DC, any suggestions?
Vehicle is always fully loaded with roof top tent and all the camping gear plus 40 litres of water and and additional 40 litres of fuel.
Plans are to have the ECU remapped for more power, but would like to upgrade the brakes first to allow for this?
Cheers
G
Old April 29th, 2015, 07:38 AM
Do you have solid or vented front disc brakes? Is the rear disc or drum?
As to the ECU remap, the amount of gained horsepower will not effect your ability to brake, even with stock. Like maybe two or three extra squirrelpower.
Old April 29th, 2015, 11:59 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Originally Posted by Celtic Nomad View Post
Hi All, I am looking to upgrade the standard brakes on my 110DC, any suggestions? Vehicle is always fully loaded with roof top tent and all the camping gear plus 40 litres of water and and additional 40 litres of fuel. Plans are to have the ECU remapped for more power, but would like to upgrade the brakes first to allow for this? Cheers G
try ebc red or green pads to start with.
Old April 29th, 2015, 12:10 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
I've tried several different approaches to this...the last was using EBC. It still won't brake like a modern vehicle. I going with a brick on a rope next
Old April 29th, 2015, 12:12 PM
tjfslaughter
thomas
Burbon
the OP has a puma
Old April 29th, 2015, 12:17 PM
Bill Larson
Bill Larson
ah...lol. well there you have it...a more modern ride. My government like it when I drive "the less safe" vehicle.
Old April 29th, 2015, 12:57 PM
I don't think PUMA brakes are any different to what would be in NAS truck.
There are limits on what can fit in a 16" rim and what is in a Defender is pretty damn good. My 90 stops as well as any modern vehicle. No problem locking up all 4 at any speed. In fact, I prefer the 90 over modern vehicles as the newer ones tend to be over boosted making modulation difficult.
On a heavy 110, you are probably stretched. The only bigger brakes I've seen are insanely expensive and require larger wheels.
Old April 29th, 2015, 01:14 PM
tjfslaughter
thomas
Burbon
I would think that the ABS, Traction Control, wheel speed sensors, brembo rotors from factory, and 4 piston calipers would be different than a NAS rig.
Old April 29th, 2015, 01:26 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
You'd think they'd be much different, but they're about the same.
Old April 29th, 2015, 06:25 PM
You must have a problem with your brakes. I can lock mine up on the highway.
Old April 29th, 2015, 06:45 PM
Bill Larson
Bill Larson
No they stop fine, like you'd expect I guess...they just don't "feel" right. The pads have been changed three times, the booster, steel flex line extensions...it's just not a firm pedal like in "modern" vehicles. I have full confidence in it's ability to stop, even while trailering a load.
Old April 29th, 2015, 06:49 PM
Pretty sure they use the same size 4 piston, 46 mm calipers and rotors on current trucks as on the NAS trucks. If they were bigger, people would be all over putting them on earlier trucks.
Old April 29th, 2015, 06:50 PM
tjfslaughter
thomas
Burbon
I might be thinking of non vented single piston earlier brakes.
Old April 29th, 2015, 06:59 PM
From what I can see the part numbers are unchanged from 1994 model year to current for calipers. All lockheed, 46 mm, 4 piston.
Old April 29th, 2015, 07:01 PM
On a Defender front??? I've never seen fronts that are not 4 piston. There are smaller 41 mm pistons, but that is about it. All rears are 2 pistons.
Never seen a 1 piston (floating caliper) on a Land Rover.
Old April 29th, 2015, 07:19 PM
tjfslaughter
thomas
Burbon
On a Defender front??? I've never seen fronts that are not 4 piston. There are smaller 41 mm pistons, but that is about it. All rears are 2 pistons. Never seen a 1 piston (floating caliper) on a Land Rover.
thanks for the research. I remember some upgrades since 93 on the pads but don't have the Parts in front of me. I know that the rear calipers have changed over the years and there is a difference between vented and non vented on the front. Thank you for clarifying it.
brake
Series III brake upgrades 76ROVER Series Technical Discussions 3 March 3rd, 2011 08:48 PM
Brake Upgrades? fleabus Defender Technical Discussions 17 September 21st, 2008 12:44 PM
Brake line upgrades - what/where to buy? pmd Defender Technical Discussions 11 March 30th, 2007 11:58 PM
D90 Suspension Upgrades? Inkopah_D90 Defender Technical Discussions 6 June 16th, 2004 07:12 PM
original 94 tires- upgrades coming jstrong98 Defender Technical Discussions 3 June 11th, 2004 11:34 AM
