Brake Switch? - Page 2 - Defender Source
Old August 23rd, 2016, 03:44 PM
RBBailey
RBBailey
1965 IIa
Thanks for replies on this. I'm going to get back to this problem once I get the truck running. First things first.
Project:
1965 IIa SWB
Old September 6th, 2016, 10:35 AM
If you want metal, you can retrofit a difflock switch onto the tower.
-Jeff
I looked at this today as I was changing a dead diff lock switch. The diff lock switch closes when pressed. For a brake light switch, you want it open when pressed. Or am I missing something?
I don't think they are the same thread either. The diff lock switch is 3/8" UNC (which is really weird on a Land Rover). The brake light switch looks to be a fine thread, 1/2" UNF according to the internet.
Brake light switch
http://www.vehiclepartsdatabase.com/...s/lucas/smb419
Diff lock switch
http://www.vehiclepartsdatabase.com/...s/lucas/smb485
Old September 6th, 2016, 11:54 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
What vehicle is this and what tower does it have?
Regarding the plastic switch for the defender style vehicles:
If the switch gets screwed in too far, it can gall the plastic and prevent the center button from coming out rendering the switch inoperative.
Also a lot of the threads in the plastic switches are of poor quality.
I always chase the threads with a dye before installing.
The length of threads you screw in is how the switch is adjusted and there should be a nut to lock the switch in place.
It's plastic, so take care not to over tighten.
RDavisinVA
Old September 11th, 2016, 01:56 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
Robert, I had this same exact problem. I used my stock tower with a Disco booster and master. With the stock brake light switch barely threaded it was already activating. I ordered this switch from EBay for $6 and it worked great. The button at the end of the switch doesn't activate as quick as the Land Rover switch does so you can thread it in a couple turns.
Standard Motor Products SLS66 Brake Light Switch
Old September 11th, 2016, 05:48 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Thanks for sharing.
RDavisinVA
brake, switch
Fog or Aux Light Switch/Plug & Switch Plate DPdotCOM Wanted 8 February 22nd, 2016 12:36 PM
light switch(like the dimmer switch) defender1844 Wanted 3 May 25th, 2014 05:42 PM
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 11:30 AM
Rollover switch? Fuel pump kill switch? tebby Defender Technical Discussions 1 July 9th, 2013 12:23 PM
Aux. light switch (RRC headlight switch) $40 shipped evilfij For Sale - Parts 0 September 5th, 2008 04:12 PM
