Brake servo - Defender Source
Old February 14th, 2013, 07:09 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Brake servo
Any problem with using a brake servo that was originally meant for a truck with ABS?
It was off a 2003 truck and I'm going to use it on my 90 without ABS. I need a master to go with it if anyone has one.
Old February 14th, 2013, 07:59 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Well I think the master cylinder you are going to use has to match the servo. For example, the stock master cylinder's mounting bolts are not slanted as that appears to be... they are both horizontally level.
Old February 15th, 2013, 06:28 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I found a master that will work, but its $223.
Now I'm wondering if I'm better off using and old style servo and master or the pictured servo with the newer style master that was meant for a truck with ABS?
I don't mind spending the extra money if will work better than the old style setup.
Old February 18th, 2013, 06:40 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Anyone see a problem using a DII brake master on a non abs truck?
Old February 18th, 2013, 06:54 PM
I would just look for a take off assembly from a non-ABS truck and replace the MC with new (they are cheap new) (or use the one off the 83 donor with a new MC) Usually the ABS systems have a smaller res. so I am not sure what the MC for that thing looks like but why reinvent the wheel.
Old February 18th, 2013, 07:06 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
http://www.carpartsdiscount.com/auto...ml?3593=123077
This is what it looks like, it's actually very large.
brake
Dia. of US spec D90 brake servo? TeriAnn Defender Technical Discussions 0 May 9th, 2012 10:49 AM
Brake fluid leaking into servo? easy Defender Technical Discussions 3 August 3rd, 2009 04:55 PM
Bad Servo? dfscott Defender Technical Discussions 0 March 25th, 2006 02:09 PM
Brake Servo dimcon Defender Technical Discussions 0 May 26th, 2005 09:20 PM
